Luke 42234 Posted March 2, 2016 Posted March 2, 2016 That's fine, just let me know what the LG-specific issues are.
eraser8 55 Posted March 2, 2016 Posted March 2, 2016 (edited) How do you work to build a specific client package? (like LG) do you want me to push you only file that need to be modify? So, when you will build the LG package, you just override the Master Web branch with the files from LG branch? If you want to have a better conversation about that, please just msg me in my inbox. BTW, I'm currently at work!! Thanks Edited March 2, 2016 by eraser8
Luke 42234 Posted March 2, 2016 Posted March 2, 2016 we would just start by creating a package without worrying about whether what aspects of the app need to be changed for LG. Once the package shell is created, and the app is at least trying to load, then we can go from there.
anderbytes 141 Posted March 2, 2016 Posted March 2, 2016 (edited) I'd buy this LG APP :D ps: I don`t know if putting an imagine like this is against the rules. If it is, I`ll discard it at once. Edited March 2, 2016 by anderbytes 3
anderbytes 141 Posted March 2, 2016 Posted March 2, 2016 How do you work to build a specific client package? (like LG) do you want me to push you only file that need to be modify? So, when you will build the LG package, you just override the Master Web branch with the files from LG branch? If you want to have a better conversation about that, please just msg me in my inbox. BTW, I'm currently at work!! Thanks Please consider that the app has to work with localization, so it won`t crash outside US... Another user is developing a LG App, and its not working for users that tried outside US. Tnx
Luke 42234 Posted March 2, 2016 Posted March 2, 2016 have you tested the app (in chrome?). it's very nice. And you guys are going to be able to build your own skins. See here: http://emby.media/community/index.php?/topic/32015-okuru-theme-wip/
StealthDefender 29 Posted March 13, 2016 Posted March 13, 2016 Any news on a lg webos app? Would go to by me a new tv and probably the use of my htpc would be useless with this app ;-) Greetz Stealth
Luke 42234 Posted March 13, 2016 Posted March 13, 2016 We have the new Emby Theater running beautifully on LG. I can't offer an ETA, but if the TV has a web browser you can follow the progress by checking out tv.emby.media. 2
StealthDefender 29 Posted March 13, 2016 Posted March 13, 2016 We have the new Emby Theater running beautifully on LG. I can't offer an ETA, but if the TV has a web browser you can follow the progress by checking out tv.emby.media.Thx Luke for answer!Ok i take a look on this. But would it not simpler to start an app than open web browser then connect to emby.media? I must say i dont have any webos at this moment to look at it! I think it would be great to stream movies and series direct from the folder without transcoding or something! Is this the way it should work?! Greetz Stealth Gesendet von meinem LG-D855 mit Tapatalk
anderbytes 141 Posted March 13, 2016 Posted March 13, 2016 Thx Luke for answer! Ok i take a look on this. But would it not simpler to start an app than open web browser then connect to emby.media? I must say i dont have any webos at this moment to look at it! I think it would be great to stream movies and series direct from the folder without transcoding or something! Is this the way it should work?! Greetz Stealth Gesendet von meinem LG-D855 mit Tapatalk Be patient. I'm sure they are working to create the best experience possible. 1
Jonz 11 Posted March 14, 2016 Posted March 14, 2016 We have the new Emby Theater running beautifully on LG. I can't offer an ETA, but if the TV has a web browser you can follow the progress by checking out tv.emby.media. Sounds good. I'll go back to check out with the my LG's. Will it support both NetCast & WebOS?
anderbytes 141 Posted March 14, 2016 Posted March 14, 2016 I did some testing and the results so far weren't so good: TV1 - LG WebOs v1 - Digital Certificate warning at the address bar. - Works but posters were squeezed to the left instead of well-arranged in the screen. Texts also got hidden or gone to the back of images. TV2 - LG WebOs v2 - Digital Certificate error (with red X) at the address bar - Didnt work. Nothing appears when entered https://tv.emby.media at the address bar.
Luke 42234 Posted March 14, 2016 Posted March 14, 2016 just keep it simple and do http for now. the browser address bar takes up space and reduces the layout to the next smallest size, e.g. 1080p -> 720p. that won't happen with the native app.
anderbytes 141 Posted March 14, 2016 Posted March 14, 2016 Thanks. I'll be waiting for the native app w/ https . I'm a little paranoid about plain http
Artweb1991 12 Posted March 14, 2016 Author Posted March 14, 2016 Hi art, Will it be necessary a "Developer Mode" to use your software, or are you thinking in publishing it to LG STORE ? No, but the application will not be taken in the store. Likely.
medric 5 Posted March 15, 2016 Posted March 15, 2016 yes this is going to be an official emby app. if you would like to contribute, i can create the LG repo now and you can fork and start pushing updates. can you create a fork and or have access so we can try to get this working on the 2014+ Panasonic viera tv's
dragon2611 29 Posted March 18, 2016 Posted March 18, 2016 I did some testing and the results so far weren't so good: TV1 - LG WebOs v1 - Digital Certificate warning at the address bar. - Works but posters were squeezed to the left instead of well-arranged in the screen. Texts also got hidden or gone to the back of images. TV2 - LG WebOs v2 - Digital Certificate error (with red X) at the address bar - Didnt work. Nothing appears when entered https://tv.emby.media at the address bar. My webOS V2 tv is the same, browser doesn't load the page.
SupaMonkey 2 Posted March 21, 2016 Posted March 21, 2016 Awesome! Saw this thread and signed up for a lifetime emby membership! Going to go try this on my LG tv right now
Luke 42234 Posted March 21, 2016 Posted March 21, 2016 Awesome! Saw this thread and signed up for a lifetime emby membership! Going to go try this on my LG tv right now Hello and welcome
StealthDefender 29 Posted March 21, 2016 Posted March 21, 2016 My tv will arrive in the next 2 days! I hope i get the same great performance and feels like with the emby kodi plugin....only without the htpc! Greetz Stealth Gesendet von meinem LG-D855 mit Tapatalk
eraser8 55 Posted March 21, 2016 Posted March 21, 2016 Hi guys, The web client currently works better now. It is surely not completed but I can play almost movies (not HEVC yet). I will talk with Luke to give you an IPK package to allow you to install it and test it on your TV. Will be back soon with a link. 1
matt_ttam123 6 Posted March 24, 2016 Posted March 24, 2016 No, but the application will not be taken in the store. Likely. Can't wait to try out the app on my lg tv, it fits in perfectly with the rest of the apps on there!
StealthDefender 29 Posted March 24, 2016 Posted March 24, 2016 (edited) My webOS V2 tv is the same, browser doesn't load the page.Got mine tv today and mine load the site also not!I try also my internal ip adress of my emby server but nothing loads. Will give it a try tomorrow. Greetz Stealth Edit: I dont know whats wrong but i cannot connect in any way to the emby server! Today i got an update from webos..... Only a lock with red cross is showing in adress bar! Sadly i cant play files over the share hub they wont load. Is there no mkv support from the lg? Gesendet von meinem LG-D855 mit Tapatalk Edited March 25, 2016 by StealthDefender
