DarkKniyt (John) 6 Posted January 10, 2016 Posted January 10, 2016 I've started having an issue when trying to connect to Emby on my Fire TV box. When I select Emby it tries to automatically connect (I ses "Loadin") on the screen for about 30 seceonds or so. I then receive the "Error Signing In" message. I select "No" to send report. I then get to the "Select a Server" or "Other Options" screen. The problem is this.... Under "Other Options" I see the "Enter Manually" and the "Logout of Connect", which I'm assuming means I'm connected to "Emby Connect". When I look at the "Select a Server" box it shows my Server, but the IP Adress is wrong. I went to Emby Connect on the web and when I sign in there the IP is correct and I can sign in just fine. Back on the Fire TV if I select to "Enter Manually", I can enter the correct IP and sign in just fine. Of course, I have to do this each time I want to watch Emby. Any troubleshooting ideas I can try? Appreciate any help! Thanks.
Luke 42243 Posted January 10, 2016 Posted January 10, 2016 It sounds like you are signed into connect but it wasn't able to connect to your server, probably due to the ip address.
SaschaBaetz 0 Posted January 28, 2016 Posted January 28, 2016 Same issue here over remote. if i try the webadress manually, login works fine. but i hve to enter the whole adress every time i want to login.
Luke 42243 Posted January 28, 2016 Posted January 28, 2016 Same issue here over remote. if i try the webadress manually, login works fine. but i hve to enter the whole adress every time i want to login. What address works manually?
Redshirt 1487 Posted January 28, 2016 Posted January 28, 2016 Same issue here over remote. if i try the webadress manually, login works fine. but i hve to enter the whole adress every time i want to login. Try clicking 'clear data' (Settings/Apps/Emby Android TV) next time your on your local network. The client will have to rediscover the server and then see if the remote issue persists after that.
