fc7 123 Posted January 11, 2016 Posted January 11, 2016 Sorry to seem to be spamming the topic, but I just noticed something else: I couldn't ever see anything in the most recent log that revealed the reason for the crash, but if I look in the penultimate log....I see this at the end (I can't attach the whole log as it's 40MB) 2016-01-10 17:37:53.8991 Info MediaEncoder: Killing ffmpeg process 2016-01-10 17:37:53.8991 Error MediaEncoder: Error sending q command to process 2016-01-10 17:37:53.8991 Error MediaEncoder: Error in WaitForExit 2016-01-10 17:37:53.8991 Error MediaEncoder: Error killing process *** Error Report *** Version: 3.0.5785.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.10.0.229 Processor count: 1 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Mon Dec 28 00:10:17 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe No process to kill. System.SystemException at System.Diagnostics.Process.Close (Int32 signo) <0x41494790 + 0x000ab> in <filename unknown>:0 at System.Diagnostics.Process.Kill () <0x41494760 + 0x00013> in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Kill () at MediaBrowser.MediaEncoding.Encoder.MediaEncoder.StopProcess (MediaBrowser.MediaEncoding.Encoder.ProcessWrapper process, Int32 waitTimeMs, Boolean enableForceKill) <0x41494000 + 0x001ff> in <filename unknown>:0 2016-01-10 17:37:53.8991 Info MediaEncoder: Killing ffmpeg process 2016-01-10 17:37:53.8991 Error MediaEncoder: Error sending q command to process 2016-01-10 17:37:53.8991 Error MediaEncoder: Error in WaitForExit 2016-01-10 17:37:53.8991 Error MediaEncoder: Error killing process *** Error Report *** Version: 3.0.5785.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.10.0.229 Processor count: 1 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Mon Dec 28 00:10:17 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe No process to kill. System.SystemException at System.Diagnostics.Process.Close (Int32 signo) <0x41494790 + 0x000ab> in <filename unknown>:0 at System.Diagnostics.Process.Kill () <0x41494760 + 0x00013> in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Kill () at MediaBrowser.MediaEncoding.Encoder.MediaEncoder.StopProcess (MediaBrowser.MediaEncoding.Encoder.ProcessWrapper process, Int32 waitTimeMs, Boolean enableForceKill) <0x41494000 + 0x001ff> in <filename unknown>:0 2016-01-10 17:37:53.8991 Info App: Disposing SsdpHandler 2016-01-10 17:37:53.9021 Info App: Disposing ActivityRepository 2016-01-10 17:37:53.9025 Info App: Disposing MovieDbProvider 2016-01-10 17:37:53.9025 Info App: Disposing EmbyTV 2016-01-10 17:37:53.9060 Info App: Disposing OpenSubtitleDownloader 2016-01-10 17:37:53.9066 Info App: Disposing LinuxIsoManager 2016-01-10 17:37:53.9066 Info App: Disposing LinuxMount 2016-01-10 17:37:53.9066 Info App: Disposing ApiEntryPoint 2016-01-10 17:37:53.9076 Info App: Disposing ServerEntryPoint 2016-01-10 17:37:53.9086 Info App: Disposing ActivityLogEntryPoint 2016-01-10 17:37:53.9141 Info App: Disposing AutomaticRestartEntryPoint 2016-01-10 17:37:53.9141 Info App: Disposing ExternalPortForwarding 2016-01-10 17:37:53.9177 Info App: Disposing LibraryChangedNotifier 2016-01-10 17:37:53.9181 Info App: Disposing LoadRegistrations 2016-01-10 17:37:53.9181 Info App: Disposing Notifications 2016-01-10 17:37:53.9194 Info App: Disposing WebSocketNotifier 2016-01-10 17:37:53.9194 Info App: Disposing RefreshUsersMetadata 2016-01-10 17:37:53.9194 Info App: Disposing UsageEntryPoint 2016-01-10 17:37:53.9194 Info App: Disposing ConnectEntryPoint 2016-01-10 17:37:53.9194 Info App: Disposing UdpServerEntryPoint 2016-01-10 17:37:53.9210 Info App: Disposing ServerEventNotifier 2016-01-10 17:37:53.9249 Info App: Disposing UserDataChangeNotifier 2016-01-10 17:37:53.9253 Info App: Disposing LibraryMonitorStartup 2016-01-10 17:37:53.9253 Info App: Disposing EntryPoint 2016-01-10 17:37:53.9253 Info App: Disposing HdHomerunDiscovery 2016-01-10 17:37:53.9253 Info App: Disposing NewsEntryPoint 2016-01-10 17:37:53.9253 Info App: Disposing DlnaProfileEntryPoint 2016-01-10 17:37:53.9253 Info App: Disposing DlnaEntryPoint 2016-01-10 17:37:53.9302 Info App: Disposing EntryPoint 2016-01-10 17:37:53.9302 Info App: Disposing KeepServerAwake 2016-01-10 17:37:53.9302 Info App: Disposing StartupWizard This would explain why we seem to be able to watch a movie and then it crashes. We need the full log. Is it 40MB before or after compression? It's a text file, so it should compress really well.
djotaku 3 Posted January 11, 2016 Author Posted January 11, 2016 Later today I'll compress it & upload it - what do you prefer? tgz or zip? As an aside to anyone else following this topic and reading this far - the change I made to the systemd file to make it restart is working well as a nice workaround until we figure out the reason for the crash. It allows my wife and kid to always find a working emby.
fc7 123 Posted January 11, 2016 Posted January 11, 2016 Later today I'll compress it & upload it - what do you prefer? tgz or zip? As an aside to anyone else following this topic and reading this far - the change I made to the systemd file to make it restart is working well as a nice workaround until we figure out the reason for the crash. It allows my wife and kid to always find a working emby. Any of those format will be the same for me.
djotaku 3 Posted January 11, 2016 Author Posted January 11, 2016 Ok, here's the compressed log file.server-63588041004.txt.tar.gz
fc7 123 Posted January 12, 2016 Posted January 12, 2016 (edited) After reviewing your log file I would try to disable the automatic subtitle fetching from OpenSubtitles. I didn't have the time to review the log deeply but it seems that you are hitting the limit of subtitles that OpenSubtitles allows you to download, so the Emby task that grabs the subs starts to fail over and over again. 2016-01-10 17:32:34.3796 Info App: HttpClientManager POST: http://api.opensubtitles.org/xml-rpc 2016-01-10 17:32:34.5083 Error App: Error downloading subtitles *** Error Report *** Version: 3.0.5785.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /var/lib/emby-server -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.10.0.229 Processor count: 1 64-Bit OS: True 64-Bit Process: True Program data path: /var/lib/emby-server Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Mon Dec 28 00:10:17 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Subtitle with Id 1953632029 was not found. Name: SubtitleDownload method response. Status: SubtitleDownload method response hold all expected values from server.. Message: 407 Download limit reached MediaBrowser.Common.Extensions.ResourceNotFoundException at MediaBrowser.Providers.Subtitles.OpenSubtitleDownloader+<GetSubtitlesInternal>c__async0.MoveNext () <0x412047f0 + 0x009e7> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x411a86b0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x411a8490 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x411a8410 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x40c35410 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x40c6d0e0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Providers.Subtitles.SubtitleManager+<DownloadSubtitles>c__async1.MoveNext () <0x41202c30 + 0x00363> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x411a86b0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x411a8490 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x411a8410 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x40c35410 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () <0x40c353e0 + 0x00013> in <filename unknown>:0 at MediaBrowser.Providers.MediaInfo.SubtitleDownloader+<DownloadSubtitles>c__async1.MoveNext () <0x411dfe50 + 0x01043> in <filename unknown>:0 Note the: Message: 407 Download limit reached The server try to cancel the task but it can't and decides to shutdown itself. 2016-01-10 17:37:48.7113 Info App: Download missing subtitles: Timed out waiting for task to stop To summarize: try to disable scheduled task that grabs the subs from OpenSubtitles and see if the problem goes away. If it does, then consider checking with OpenSubtitles how can you raise the limit of subtitles you can download per day (probably you will need a premium account or something). Edited January 12, 2016 by fc7
djotaku 3 Posted January 12, 2016 Author Posted January 12, 2016 I'll turn it off, but it's a red herring. It was happening before I started grabbing from opensubtitles.
fc7 123 Posted January 12, 2016 Posted January 12, 2016 I'll turn it off, but it's a red herring. It was happening before I started grabbing from opensubtitles. Ok. So start by turning that off. This should give us a much cleaner log (without all the subtitles errors) and once the problem happens again upload the new log and I will check it again. What do you think?
djotaku 3 Posted January 12, 2016 Author Posted January 12, 2016 Yup. Just turned it off. I'll start with the 542PM log for today and submit any more logs that are made today before I end my day.
djotaku 3 Posted January 13, 2016 Author Posted January 13, 2016 I'm attaching my logs. If you know naming system that lets you know which are the most recent, you can filter that out. If not, I'll have to upload the just most recent ones tomorrow.server-63587925593.txt.tar.gz
fc7 123 Posted January 13, 2016 Posted January 13, 2016 (edited) I'm attaching my logs. If you know naming system that lets you know which are the most recent, you can filter that out. If not, I'll have to upload the just most recent ones tomorrow.server-63587925593.txt.tar.gz Did Emby crash again? If yes, please post the time it crashed, at least approximately. Edit: sorry but I can't review so many log files to find the latests logs. Please only upload the latest log, after the server is crashing otherwise I will not analyze them. Thanks. Edited January 13, 2016 by fc7
djotaku 3 Posted January 13, 2016 Author Posted January 13, 2016 Sorry about. Yes, it crashed about 5-7 times. That's why there were so many logs. I'll try again when I get home today to grab the last two.
djotaku 3 Posted January 13, 2016 Author Posted January 13, 2016 Ok, so there was a crash because this is what I get when I interrogate the status: # systemctl status emby-server ● emby-server.service - Emby Media Server Loaded: loaded (/usr/lib/systemd/system/emby-server.service; disabled; vendor preset: disabled) Active: active (running) since Wed 2016-01-13 16:12:49 EST; 1h 4min ago Process: 2117 ExecStopPost=/usr/lib/emby-server/emby-server.sh clear (code=exited, status=0/SUCCESS) Main PID: 2131 (su) CGroup: /system.slice/emby-server.service ‣ 2131 su -s /bin/sh -c exec "$0" "$@" emby -- env MONO_THREADS_PER_CPU=500 MONO_GC_PARAMS=nursery-size=128m LD_LIBRARY_PATH=/usr/lib/emby-server/lib64 /usr/bin/mono-sgen --optimize=all /usr/lib/emby... Jan 13 16:12:49 babyluigi.mushroomkingdom systemd[1]: Started Emby Media Server. Jan 13 16:12:49 babyluigi.mushroomkingdom systemd[1]: Starting Emby Media Server... Jan 13 16:12:49 babyluigi.mushroomkingdom su[2131]: (to emby) root on none And it should have been running for days now. Here are the last two logs. server-63588293647.txtserver-63588298370.txt
fc7 123 Posted January 14, 2016 Posted January 14, 2016 (edited) Ok, so there was a crash because this is what I get when I interrogate the status: # systemctl status emby-server ● emby-server.service - Emby Media Server Loaded: loaded (/usr/lib/systemd/system/emby-server.service; disabled; vendor preset: disabled) Active: active (running) since Wed 2016-01-13 16:12:49 EST; 1h 4min ago Process: 2117 ExecStopPost=/usr/lib/emby-server/emby-server.sh clear (code=exited, status=0/SUCCESS) Main PID: 2131 (su) CGroup: /system.slice/emby-server.service ‣ 2131 su -s /bin/sh -c exec "$0" "$@" emby -- env MONO_THREADS_PER_CPU=500 MONO_GC_PARAMS=nursery-size=128m LD_LIBRARY_PATH=/usr/lib/emby-server/lib64 /usr/bin/mono-sgen --optimize=all /usr/lib/emby... Jan 13 16:12:49 babyluigi.mushroomkingdom systemd[1]: Started Emby Media Server. Jan 13 16:12:49 babyluigi.mushroomkingdom systemd[1]: Starting Emby Media Server... Jan 13 16:12:49 babyluigi.mushroomkingdom su[2131]: (to emby) root on none And it should have been running for days now. Here are the last two logs. server-63588293647.txtserver-63588298370.txt I checked both logs but I can't find any evidence that suggests that the server crashed or had any important problem. Having said that, maybe these are not the correct logs (I think these are the logfiles after the server last restart but we need the previous ones that may include the problem). What I would suggest you is to: Stop the Emby server service Rollback the modification you made to the service file to automatically restart the service Start the Emby server service. This time write down the date and time when the server is starting. If it crashes again, then grab all the log files between the date the server started until the last one available (that should include the crash). Once we have this information, post it here and you can reconfigure the service again to autorestart if you wish. Edited January 14, 2016 by fc7
djotaku 3 Posted January 15, 2016 Author Posted January 15, 2016 OK, I'll give it a shot when I get a chance
djotaku 3 Posted January 16, 2016 Author Posted January 16, 2016 OK, last night at 8:41PM I started the server. This was the status before I retired for the night: systemctl status emby-server ● emby-server.service - Emby Media Server Loaded: loaded (/usr/lib/systemd/system/emby-server.service; disabled; vendor preset: disabled) Active: active (running) since Fri 2016-01-15 20:41:41 EST; 3h 6min ago Process: 9443 ExecStopPost=/usr/lib/emby-server/emby-server.sh clear (code=exited, status=0/SUCCESS) Main PID: 9463 (su) CGroup: /system.slice/emby-server.service ‣ 9463 su -s /bin/sh -c exec "$0" "$@" emby -- env MONO_THREADS_PER_CPU=500 MONO_GC_PARAMS=nursery-size=128m LD_LIBRARY_PATH=/usr/lib/emby-server/lib64 /usr/bin/mono-sgen --optimize=all /usr/lib/emby... Jan 15 20:41:41 babyluigi.mushroomkingdom systemd[1]: Started Emby Media Server. Jan 15 20:41:41 babyluigi.mushroomkingdom systemd[1]: Starting Emby Media Server... Jan 15 20:41:41 babyluigi.mushroomkingdom su[9463]: (to emby) root on none This morning, around 730AM my wife tried to watch on Kodi and it wouldn't connect. My android app would not connect. Here is the current status: ● emby-server.service - Emby Media Server Loaded: loaded (/usr/lib/systemd/system/emby-server.service; disabled; vendor preset: disabled) Active: failed (Result: exit-code) since Sat 2016-01-16 00:19:36 EST; 7h ago Process: 10059 ExecStopPost=/usr/lib/emby-server/emby-server.sh clear (code=exited, status=0/SUCCESS) Process: 9463 ExecStart=/usr/lib/emby-server/emby-server.sh start (code=exited, status=134) Main PID: 9463 (code=exited, status=134) Jan 15 20:41:41 babyluigi.mushroomkingdom systemd[1]: Started Emby Media Server. Jan 15 20:41:41 babyluigi.mushroomkingdom systemd[1]: Starting Emby Media Server... Jan 15 20:41:41 babyluigi.mushroomkingdom su[9463]: (to emby) root on none Jan 16 00:19:36 babyluigi.mushroomkingdom systemd[1]: emby-server.service: main process exited, code=exited, status=134/n/a Jan 16 00:19:36 babyluigi.mushroomkingdom systemd[1]: Unit emby-server.service entered failed state. Jan 16 00:19:36 babyluigi.mushroomkingdom systemd[1]: emby-server.service failed. So it died about 45 minutes after I stopped checking if it was going to die. Here are the logs. server-63588482997.txtserver-63588487302.txtserver-63588499200.txttranscode-4f44c926-b073-4089-a9f2-0f85507d1d64.txttranscode-86cfa2dd-e5cc-4555-9203-fae3f83017bd.txt This is the order they go in: -rw-r--r--. 1 emby 250246 Jan 15 20:40 server-63588482997.txt -rw-r--r--. 1 emby 30550 Jan 15 20:47 transcode-4f44c926-b073-4089-a9f2-0f85507d1d64.txt -rw-r--r--. 1 emby 28325 Jan 15 21:14 transcode-86cfa2dd-e5cc-4555-9203-fae3f83017bd.txt -rw-r--r--. 1 emby 1319735 Jan 16 00:00 server-63588487302.txt -rw-r--r--. 1 emby 74745 Jan 16 00:19 server-63588499200.txt
Luke 42244 Posted January 16, 2016 Posted January 16, 2016 there's a lot of dlna traffic, so you could try turning off the dlna server and play to features in the server web interface under Dlna
djotaku 3 Posted January 16, 2016 Author Posted January 16, 2016 If there were any question about whether it had to do with the RAM, I boosted the RAM to 4GB today. Still crashed. I'm now going to turn off the DLNA - would I need to restart the server after that ? Or is it immediate?
Luke 42244 Posted January 16, 2016 Posted January 16, 2016 iimmediate but i would also consider restarting.
drewbuchman 0 Posted January 28, 2016 Posted January 28, 2016 I am having this same issue on the same version. It only does this during idle not while playing items. My system specs are below Centos7 Dell 1950 power edge 2 x 2.3 quad core xeon 64 gb ram 4991 tv episodes 1089 Movies 20000 songs
Luke 42244 Posted January 28, 2016 Posted January 28, 2016 I am having this same issue on the same version. It only does this during idle not while playing items. My system specs are below Centos7 Dell 1950 power edge 2 x 2.3 quad core xeon 64 gb ram 4991 tv episodes 1089 Movies 20000 songs Hi, in order to best help you, please see how to report a problem. Thanks. 1
drewbuchman 0 Posted January 28, 2016 Posted January 28, 2016 Here are my logs ill gave to send in 3 posts due to size log 1-25.txt
djotaku 3 Posted January 28, 2016 Author Posted January 28, 2016 I am having this same issue on the same version. It only does this during idle not while playing items. My system specs are below Centos7 Dell 1950 power edge 2 x 2.3 quad core xeon 64 gb ram 4991 tv episodes 1089 Movies 20000 songs I guess now I don't feel like it's my fauilt for having a low-powered machine. 1
FingerlessGlovs 8 Posted January 28, 2016 Posted January 28, 2016 (edited) I've got the same issue. Fresh install and i just moved from using Ubuntu server. Specs 6 core amd 1090t 12gb ram Centos7 Kernel 4.4 200+ movies 2000+ TV epoisodes. Latest emby from repo stable. My dlna is also getting spamed in my logs. Mono is still running emby when it crashes/becomes unrespondise. Some times mono gets killed/terminated when it crashes Edited January 28, 2016 by MrJonny
