Nuk3na 2 Posted January 9, 2016 Posted January 9, 2016 I uninstall it reboot the server and it does not remove its self. Any ideas?
Luke 42243 Posted January 9, 2016 Posted January 9, 2016 Hi. In order for us to best help you, please see how to report a problem so that additional information can be provided. Thanks.
Nuk3na 2 Posted January 9, 2016 Author Posted January 9, 2016 (edited) Some of my logs can be seen in this post from an hour ago. http://emby.media/co...ror-in-my-logs/ Theres my logs in a previous post from earlier. Im on Debian 8 and the latest version of emby my logs may say an older version as I have only just updated due to being advised to do so. Edited January 9, 2016 by Nuk3na
Nuk3na 2 Posted January 21, 2016 Author Posted January 21, 2016 Any update on this? the trailer plugin still wont remove its self from my server
Solution Luke 42243 Posted January 21, 2016 Solution Posted January 21, 2016 i would just delete the dll manually under programdata/plugins in order to give a better answer i really need a separate log dedicated solely to this issue. thanks. 1
