Shyatic 5 Posted January 9, 2016 Posted January 9, 2016 A strange issue... if I use the HDHR windows app, the TV works fine. If I go through Emby, it doesn't load. Any reason this might happen? Both on mobile and on my web client... I got it to load like... once. But after that it just sits there and doesn't do anything. Thanks for any ideas! 1
Luke 42241 Posted January 9, 2016 Posted January 9, 2016 Hi, in order for us to best help you, please see how to report a problem - Media Playback Issues. Thanks.
Shyatic 5 Posted January 9, 2016 Author Posted January 9, 2016 (edited) Attaching the log file... hope this helps! I can start the channel to play ONE time, but after that it doesn't do anything. I can still play it with the HDHR app though. I have to reboot to be able to play it again server-63587894400.txt Edited January 9, 2016 by Shyatic
Shyatic 5 Posted January 9, 2016 Author Posted January 9, 2016 Actually in a bit of irony... NOTHING is playing back right now. Can't start a movie through the web client or anything else.
Shyatic 5 Posted January 10, 2016 Author Posted January 10, 2016 I reinstalled the server from scratch -- still the same issue. I'm reattaching more logs here. server-63587983613.txt transcode-31a6d250-3a48-4984-add0-9f5c06e5bb76.txt transcode-81e44c41-b319-4fef-8e70-c793255e7c99.txt
Shyatic 5 Posted January 10, 2016 Author Posted January 10, 2016 Should note that my tuner seems to be changing the channel, but I get nothing when trying to stream through Emby.
Shyatic 5 Posted January 11, 2016 Author Posted January 11, 2016 Luke not sure if you got a chance to review, but any thoughts?
Luke 42241 Posted January 11, 2016 Posted January 11, 2016 what emby apps are you trying to play from?
Shyatic 5 Posted January 11, 2016 Author Posted January 11, 2016 (edited) I tried the web client from my desktop, as well as the Windows universal app with no joy. Again as I said... the live TV works fine from the HDHR device and the HDHR apps, just not through Emby. Emby does change the channel on the tuner (I see the log on the HDHR itself) but never makes it to my screen. Edited January 11, 2016 by Shyatic
frickinfrack 1 Posted January 12, 2016 Posted January 12, 2016 I am having the same issue. My infrastructure is all CAT5E and EMBY works perfectly for everything except live TV. Guide loads very slowly and have gotten video maybe 3 times out of 100. I use the mobile app, windows app, and have tried the web app with chrome and IE11. Not sure if related but I am unable to view DRM channels in WMC (using as standby till this is fixed) but all work fine in the HDHomerun View app. Also not sure if it matters but I have a domain here and the "Emby Server" is a VM running Win 10 with 2 cores allocated as well as 4 GB of ram. No issues with streaming or menu's loading for movies, music, or D-Loaded TV. PC's used for testing have and have not been domain joined. The server is domain joined. Firewall seems to make no difference. I'm hoping for a speedy resolution. Not sure where to find logs but had tuner status page open on other screen and Emby isn't tuning. WMC does and HDHR view works. 1
thaddeusferber 2 Posted January 13, 2016 Posted January 13, 2016 I'm facing the same thing. Works in Roku, but not in browser.
Shyatic 5 Posted January 14, 2016 Author Posted January 14, 2016 What browser? I use Chrome, will try Edge also.
Shyatic 5 Posted January 14, 2016 Author Posted January 14, 2016 (edited) Should note, if I tune to a channel after a reboot, it works ONCE.. after that it doesn't work at all. So I tuned to a local channel 7 to watch Jeopardy, then changed channels and boom, nothing. This is on a totally fresh install of Emby as WELL as a totally fresh install of Windows. Emby is making the call to the tuner, it just isn't displaying anything. I get the log on the HDHR device: 20160114-00:21:30 Tuner: tuner0 tuning 7 WABC (none:69MHz-7) 20160114-00:21:31 Tuner: tuner0 streaming http to 192.168.1.184:56295 20160114-00:21:31 CableCARD: tuner0 7 WABC (none:69MHz-7) access = subscribed 20160114-00:21:59 Tuner: tuner0 tuning 43 AMC (none:483MHz-43) 20160114-00:21:59 Tuner: tuner0 streaming http to 192.168.1.184:56299 20160114-00:21:59 CableCARD: tuner0 43 AMC (none:483MHz-43) access = subscribed 20160114-00:22:00 CableCARD: message: /get_cc_url?CableCARD///apps/PhoneHome.html Edited January 14, 2016 by Shyatic
thaddeusferber 2 Posted January 14, 2016 Posted January 14, 2016 For me, it is working on Chrome, but not FF or IE. Also it is not working for IOS for me.
Shyatic 5 Posted January 19, 2016 Author Posted January 19, 2016 Any ideas anybody? The fact that the HDHR application works fine and Emby doesn't is kind of disappointing.
Luke 42241 Posted January 19, 2016 Posted January 19, 2016 can you please try the latest release of the server as i've put in some firefox fixes. i am not able to reproduce any of this i'm afraid.
revengineer 142 Posted January 28, 2016 Posted January 28, 2016 (edited) For me, it is working on Chrome, but not FF or IE. Also it is not working for IOS for me. This is exactly my experience with server version 3.0.5818.0 running on WS2012E. I see the ffmpeg process starting on the server and then stopping again. Also the tuner light n HDHR comes on briefly. After that the browser reports "Video error: There was an error playing the video. Please ensure there is an open tuner available. On the other hand, movies play fine on Firefox (v43.0.4). Here the transcode log: http://192.168.1.50:8096/emby/videos/b425f3d74cd81b744db100b785e56560/stream.webm?DeviceId=9383b9d4219b53dead239df78028e28847433aac&MediaSourceId=6b95c772019a4398bf1b9de6895f2808native&VideoCodec=vpx&AudioCodec=vorbis&AudioStreamIndex=-1&VideoBitrate=1396043636&AudioBitrate=320000&MaxAudioChannels=6&MaxHeight=1080&PlaySessionId=c7b88a7733e0400ba8b89ae7a8a562e9&api_key=3e9862489c024abd8eade8a7c0d4dca6&EnableAutoStreamCopy=false {"Protocol":"Http","Id":"6b95c772019a4398bf1b9de6895f2808native","Path":"http://192.168.1.85:5004/auto/v48","Type":"Default","Container":"ts","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":false,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"BufferMs":0,"MediaStreams":[{"Codec":"mpeg2video","IsInterlaced":true,"IsDefault":false,"IsForced":false,"Type":"Video","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false},{"Codec":"ac3","IsInterlaced":false,"BitRate":192000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false}],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":192000,"RequiredHttpHeaders":{}} C:\Users\admin\AppData\Roaming\Emby-Server\ffmpeg\20151111\ffmpeg.exe -fflags +genpts -i "http://192.168.1.85:5004/auto/v48"-sn -codec:v:0 libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "yadif=0:-1:0,scale=trunc(oh*a/2)*2:min(ih\,1080)" -pix_fmt yuv420p -speed 16 -quality good -profile:v 0 -slices 8 -crf 10 -qmin 0 -qmax 50 -maxrate:v 1396043636 -bufsize:v (1396043636*2) -b:v 1396043636 -vsync vfr -map_metadata -1 -threads 3 -codec:a:0 libvorbis -ac 6 -ab 320000 -af "aresample=async=1" -y "C:\Users\admin\AppData\Roaming\Emby-Server\transcoding-temp\ee2173962f5f95c2c1fb94da8b46fff9.webm" ffmpeg version N-76598-g2905c51 Copyright © 2000-2015 the FFmpeg developers built with gcc 5.2.0 (GCC) configuration: --arch=x86_64 --target-os=mingw32 --cross-prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/mingw-w64-x86_64/bin/x86_64-w64-mingw32- --pkg-config=pkg-config --disable-w32threads --enable-gpl --enable-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libbluray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --enable-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-libs=-lpng --enable-libvidstab --enable-libx265 --enable-decklink --extra-libs=-loleaut32 --enable-libx264 --enable-libxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --enable-frei0r --enable-filter=frei0r --enable-libvo-aacenc --enable-bzlib --enable-libxavs --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-libvpx --enable-libilbc --enable-libwavpack --enable-libwebp --enable-libgme --enable-dxva2 --enable-libdcadec --enable-avisynth --enable-gray --enable-libmfx --extra-libs=-lpsapi --extra-cflags= --enable-static --disable-shared --prefix=/home/mceuser/ffmpeg-windows-build-helpers/sandbox/mingw-w64-x86_64/x86_64-w64-mingw32 --enable-runtime-cpudetect libavutil 55. 5.100 / 55. 5.100 libavcodec 57. 15.100 / 57. 15.100 libavformat 57. 14.100 / 57. 14.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 15.100 / 6. 15.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.101 / 2. 0.101 libpostproc 54. 0.100 / 54. 0.100 [mpeg2video @ 000000db5e9854a0] Invalid frame dimensions 0x0. Last message repeated 40 times Edited January 28, 2016 by revengineer
Luke 42241 Posted January 28, 2016 Posted January 28, 2016 Sorry guys I know you're probably wondering why doesn't it just work with Browser A like it does with Browser B. We're doing our best. Delivering transcoded live tv on demand is not an easy thing to do. The more features the browser has, the easier it is to pull off. That's why it works well in Chrome, Firefox isn't bad, and IE obviously is really difficult. Despite the issues here I do think the recent changes have improved Firefox playback, see here for example: http://emby.media/community/index.php?/topic/30357-livetv-playback-firefox/?p=292901 I am still continuing to look into it though.
revengineer 142 Posted January 30, 2016 Posted January 30, 2016 No worries, I understand the difficulties. I am just supplying information in the hope they they provide a pointer.
Vitale4 15 Posted February 15, 2016 Posted February 15, 2016 I also am having some issues with this. We are using the iOS app, the Android App, and Chrome. I have found that when it starts having issues, the system needs to be restarted. Seems as though EMBY is not terminating the tuners on HDHR Prime at all times. There are times when I am watching a show, then disconnect and the HDHR Prime still shows something connected (one of the tuner lights are on). When I connect again, another Tuner Light on the box comes on, but nothing will show, you get a black screen. Hopefully this will be figured out soon. I do know this is a difficult process and appreciate what has been done to date.
Vitale4 15 Posted February 19, 2016 Posted February 19, 2016 So today I found that I was able to watch LiveTV consistently without issue if I manually set the stream to a lower value: 720P - 1 Mbps. The auto option set the stream to 720P - 6Mbps which seemed to give sporadic issues depending on where I was streaming from. At one point it was set to 1080P 60Mbps, not sure why... Just wanted to pass this on as my issues have seemed to vanish. I will also note that I am currently running EMBY Server Version 3.0.5871.0
