mini__me 28 Posted January 8, 2016 Posted January 8, 2016 I recently changed my subs preferences based on another thread here to 'smart' for subtitles, I think tonight is the first time I've used Emby since in WMC and now it would appear from the error not to like that change....
mini__me 28 Posted January 9, 2016 Author Posted January 9, 2016 Following the error I uninstalled and reinstalled from the installer on the Emby website so I assume I'm on the latest stable release. Any logs I can pull for you that would be useful?
ebr 16333 Posted January 9, 2016 Posted January 9, 2016 Can you try updating to the beta I just marked and see if that fixes it?
mini__me 28 Posted January 10, 2016 Author Posted January 10, 2016 I just installed 3.0.294 from the beta installer on the website and it displays the same error.
ebr 16333 Posted January 10, 2016 Posted January 10, 2016 Okay, it appears changes were made very recently since I had just updated a couple days ago. Please try the dev version going up now.
mini__me 28 Posted January 11, 2016 Author Posted January 11, 2016 OK stupid question coming.....how can I set it to dev without being able to launch it?
ebr 16333 Posted January 11, 2016 Posted January 11, 2016 Turn off the smart sub setting temporarily.
mini__me 28 Posted January 11, 2016 Author Posted January 11, 2016 Ha!! I thought I'd tried that already Double checking and I hadn't, stupid me! Will try it later.
mini__me 28 Posted January 12, 2016 Author Posted January 12, 2016 Can confirm 296 fixed the issue. Thank you
