RedStripe 14 Posted January 7, 2016 Posted January 7, 2016 (edited) Version 3.0.5785.0 Every time the Emby server is restarted the view order for the homepage icons is reset.Although there is an "Edit Images" option for livetv...it does not appear to work. Thanks Edited January 7, 2016 by RedStripe
Deathsquirrel 745 Posted January 7, 2016 Posted January 7, 2016 I can't reproduce this with my server. I'm not using live tv though so perhaps it requires more homescreen icons than my default 3 of Music/Movies/TV.
Luke 42185 Posted January 8, 2016 Posted January 8, 2016 Thanks. Can't reproduce either, except for the live TV thing
RedStripe 14 Posted January 11, 2016 Author Posted January 11, 2016 The view order issue seems to have self-healed. Are there plans to implement the "Edit Images" option for livetv?
jds828 24 Posted January 12, 2016 Posted January 12, 2016 Mine does it. My fix.... Do it 3 times and it stays. I put live TV at the bottom of the list. It's odd but my Mediaportal TV channels only get the right order after 3 goes too. Very odd!
