programs/emby/movies/movies == no art or info
how does this look good?
all infos available via kodi movies library normal
Edited by badaas
Angelblue05
The add-on is a video add-on, not a program add-on. So, if you access it this way, it will populate poorly because the metadata pulled/displayed is limited, since program add-ons normally only have a poster and maybe a backdrop.
Solution: access via video add-ons > emby instead.
Sent from my iPhone using Tapatalk
  • Like 1
Guest
