tlh523 3 Posted January 6, 2016 Posted January 6, 2016 (edited) I have been an EMBY user with WMC for many years.... I am now evaluating EMBY Theater LiveTV using tge WMCServer plugin. when i connect using the connect interface. I see my channels and recordings. However when I connect using the Theater interface and select LiveTV, I see the channel and recording elements, but no channels or recordings are listed. Any suggestions? Edited January 6, 2016 by tlh523
Trevor68 70 Posted January 31, 2016 Posted January 31, 2016 Hows this traveling, progress I assume as I can now see all the programs and channels populated. Unfortunately if I try to watch anything I just get a spinning circle.
krustyreturns 191 Posted January 31, 2016 Posted January 31, 2016 You are doing better then me. When I run emby theater and click 'live tv' I just get "There was an error processing that request"
gte709p 0 Posted February 17, 2016 Posted February 17, 2016 I think I may be having a similar problem. I use ServerWMC w/ my Windows Media Center PC. I have a Ceton InfiniTV 6 tuner installed for Comcast. Recording works, and I'm able to watch live TV through WMC, but if I try to PLAY live TV through Emby it doesn't work. I just updated to latest version 3.0.5871. When I try to play a channel through the web browser, sometimes I get a spinning circle, sometimes it appears that nothing happens. I also have the Emby app installed on my Roku and when I try to play live TV on there, the app crashes. Not sure if that is related to the issue of the Live TV not playing or something else with the app. Anything I can check/send to have this looked into?
