ravin_papasmurf 0 Posted January 6, 2016 Posted January 6, 2016 Have had emby for about 8 months or so. Upgraded from Win 7 to Win 10 about 2 month ago. First time having this problem. When i try to open up the sever, it loads to about 95% and stops. Ive tried going in in manually turning on ports 8096 & 8920 but to no avail. Anyone have this issue or know how to fix it?
Luke 42185 Posted January 6, 2016 Posted January 6, 2016 Hi, please provide the server log: http://emby.media/community/index.php?/topic/739-how-to-report-a-problem/
ravin_papasmurf 0 Posted January 6, 2016 Author Posted January 6, 2016 slight problem.... i'm not computer illiterate but unfort, by no means in the IT department. since i cant get the sever up, accessing the server's web interface directly doesnt work and theres no folder labled "Emby-Server", just "Emby-InstallLogs" and the files with in say that the installation completed.
ebr 16307 Posted January 6, 2016 Posted January 6, 2016 Is it possible an anti-virus program quarantined or deleted portions of the server?
ravin_papasmurf 0 Posted January 6, 2016 Author Posted January 6, 2016 no anti virus installed in the PC
Luke 42185 Posted January 6, 2016 Posted January 6, 2016 instead of the folder Emby-Server, try MediaBrowser-Server, which you might have depending on how old your installation is. I think what the log is going to show us is that it's just taking a long time to download ffmpeg, but I guess we'll find out.
ravin_papasmurf 0 Posted January 7, 2016 Author Posted January 7, 2016 (edited) thank you. I was able to obtain that log lol I've even left the sever on over night to see if it was timing issue but that didnt seem to work. 2016-01-05 22:58:57.0654 Info App: Loading MediaBrowser.Server.Implementations, Version=3.0.5782.0, Culture=neutral, PublicKeyToken=null 2016-01-05 22:58:57.0654 Info App: Loading MediaBrowser.MediaEncoding, Version=3.0.5782.0, Culture=neutral, PublicKeyToken=null 2016-01-05 22:58:57.0654 Info App: Loading MediaBrowser.Dlna, Version=3.0.5782.0, Culture=neutral, PublicKeyToken=null 2016-01-05 22:58:57.0654 Info App: Loading MediaBrowser.LocalMetadata, Version=3.0.5782.0, Culture=neutral, PublicKeyToken=null 2016-01-05 22:58:57.0654 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.0.5782.0, Culture=neutral, PublicKeyToken=null 2016-01-05 22:58:57.0654 Info App: Loading MediaBrowser.IsoMounter, Version=1.0.5344.20624, Culture=neutral, PublicKeyToken=null 2016-01-05 22:58:57.0654 Info App: Loading MediaBrowser.ServerApplication, Version=3.0.5782.0, Culture=neutral, PublicKeyToken=null 2016-01-05 22:58:57.0654 Info App: Loading MediaBrowser.Server.Startup.Common, Version=3.0.5782.0, Culture=neutral, PublicKeyToken=null 2016-01-05 22:58:57.0804 Error App: LoaderException: Could not load type 'MediaBrowser.Controller.Providers.EpisodeIdentity' from assembly 'MediaBrowser.Controller, Version=3.0.5782.0, Culture=neutral, PublicKeyToken=null'. 2016-01-05 22:58:57.3575 Info SqliteUserRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\users.db 2016-01-05 22:58:57.4485 Info SqliteFileOrganizationRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\fileorganization.db 2016-01-05 22:58:57.4485 Info AuthenticationRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\authentication.db 2016-01-05 22:58:57.4805 Info SyncRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\sync14.db 2016-01-05 22:58:57.5755 Info ImageMagick: ImageMagick version: ImageMagick 6.9.0-9 Q8 x86 2015-02-28 http://www.imagemagick.org 2016-01-05 22:58:58.6616 Info ImageProcessor: ImageProcessor started with 8 max concurrent image processes 2016-01-05 22:58:58.7366 Info App: FFMpeg: C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\ffmpeg\20151111\ffmpeg.exe 2016-01-05 22:58:58.7366 Info App: FFProbe: C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\ffmpeg\20151111\ffprobe.exe 2016-01-05 22:58:58.7366 Info SharingRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\shares.db 2016-01-05 22:58:58.7536 Info ActivityRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\activitylog.db 2016-01-05 22:58:58.7656 Info SqliteDisplayPreferencesRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\displaypreferences.db 2016-01-05 22:58:58.7656 Info SqliteItemRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\library.db 2016-01-05 22:58:58.7916 Info SqliteProviderInfoRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\refreshinfo.db 2016-01-05 22:58:58.7916 Info SqliteUserDataRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\userdata_v2.db 2016-01-05 22:58:58.8146 Info SqliteNotificationsRepository: Sqlite 3.8.6 opening C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\data\notifications.db 2016-01-05 22:58:59.0987 Info HttpServer: Calling ServiceStack AppHost.Init 2016-01-05 22:59:01.3768 Info ServiceStackHost: Initializing Application took 3862.3644ms 2016-01-05 22:59:01.3978 Info ServerManager: Loading Http Server 2016-01-05 22:59:01.4028 Info HttpServer: attempting to load pfx: C:\Users\Papa Smurf\AppData\Roaming\MediaBrowser-Server\ssl\cert_9c31b7884ea5475c8687970fc5996297.pfx 2016-01-05 22:59:01.4588 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2016-01-05 22:59:01.4588 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2016-01-05 22:59:01.7338 Info App: [TVHclient] LiveTvService() 2016-01-05 22:59:01.7338 Info App: [TVHclient] HTSConnectionHandler() 2016-01-05 22:59:01.7468 Info App: [TVHclient] HTSConnectionHandler.ensureConnection: Priority was out of range [0-4] - set to 2 2016-01-05 22:59:01.7468 Info App: [TVHclient] HTSConnectionHandler.createHTSConnection() 2016-01-05 22:59:01.7468 Info App: [TVHclient] HTSConnectionHandler.ensureConnection: Used connection parameters: TVH Server = 'localhost'; HTTP Port = '9981'; HTSP Port = '9982'; User = 'ravin_papasmurf'; Password set = 'True' 2016-01-05 22:59:01.7468 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' 2016-01-05 22:59:02.7548 Error App: [TVHclient] HTSConnectionAsync.open: caught exception : No connection could be made because the target machine actively refused it [::1]:9982 2016-01-05 22:59:04.7553 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' 2016-01-05 22:59:05.7562 Error App: [TVHclient] HTSConnectionAsync.open: caught exception : No connection could be made because the target machine actively refused it [::1]:9982 2016-01-05 22:59:07.7581 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' 2016-01-05 22:59:08.7601 Error App: [TVHclient] HTSConnectionAsync.open: caught exception : No connection could be made because the target machine actively refused it [::1]:9982 2016-01-05 22:59:10.7611 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' 2016-01-05 22:59:11.7617 Error App: [TVHclient] HTSConnectionAsync.open: caught exception : No connection could be made because the target machine actively refused it [::1]:9982 2016-01-05 22:59:13.7631 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' 2016-01-05 22:59:14.7641 Error App: [TVHclient] HTSConnectionAsync.open: caught exception : No connection could be made because the target machine actively refused it [::1]:9982 2016-01-05 22:59:16.7664 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' 2016-01-05 22:59:17.7666 Error App: [TVHclient] HTSConnectionAsync.open: caught exception : No connection could be made because the target machine actively refused it [::1]:9982 2016-01-05 22:59:19.7684 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' 2016-01-05 22:59:20.7701 Error App: [TVHclient] HTSConnectionAsync.open: caught exception : No connection could be made because the target machine actively refused it [::1]:9982 2016-01-05 22:59:22.7705 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' 2016-01-05 22:59:23.7710 Error App: [TVHclient] HTSConnectionAsync.open: caught exception : No connection could be made because the target machine actively refused it [::1]:9982 2016-01-05 22:59:25.7724 Info App: [TVHclient] HTSConnectionAsync.open: IPEndPoint = '[::1]:9982'; AddressFamily = 'InterNetworkV6' ...etc Edited January 7, 2016 by ravin_papasmurf
Luke 42185 Posted January 7, 2016 Posted January 7, 2016 that can't be the entire thing. that's not how the logs begin.
Luke 42185 Posted January 7, 2016 Posted January 7, 2016 in any event, my suggestion is to go into the plugins folder, and remove all plugin dlls, then restart the server. if it loads back up, then add the plugins back one at a time
ravin_papasmurf 0 Posted January 7, 2016 Author Posted January 7, 2016 THANK YOU! removing the plugins worked like a charm! You rock!!!
