Tanamur 53 Posted December 12, 2013 Posted December 12, 2013 MBServer: Version 3.0.5083.27698 MBClassic: Version 3.0.100.0 B12-4.1 MBTheater: Not installed PC Server OS: Windows 7 Home Premium 64-bit SP1 Codecs: Nothing other than installed with Win7 out of the box and MBServer Extender: HP MediaSmart Connect x280n I would appreciate some guidance on the MB3 preferred library structure for multi-disc music CD's to avoid multiple album/CD entries. I have just gone through a retagging exercise (thanks Luke) with Media Monkey which has greatly improved the information pulled from the tags in recent versions of MB3 Server. I did have the CD's stored as... \Music \Artist Name \Album Name - Disc 1 1- Song.mp3 2- Song.mp3 \Album Name - Disc 2 1- Song.mp3 2- Song.mp3 ...which resulted in multiple entries per album/CD and doesn't always automatically display Disc 1/Disc 2 in the name from the folder structure. Now I have renamed the physical file tracks on the discs to reflect their respective discs, tagged them as disc 1, disc 2, and combined folders as below... \Music \Artist Name \Album Name 101- Song.mp3 102- Song.mp3 201- Song.mp3 202- Song.mp3 ...but this results in duplicated track numbers and straight album play would then jump back and forth from disc/track 101 to disc/track 201, 102, 202, 103, 203, etc. Is there a track file naming convention that will let me combine disc folders and get me to the sequential track order from disc1, then disc 2 to disc x? Or, am I going about it all wrong? Thanks, Tanamur
Luke 42288 Posted December 12, 2013 Posted December 12, 2013 We read the disc number in the tags, we don't use the file names at all for that. you could try running your song through ffprobe to see what it reports because that's what we use.
Tanamur 53 Posted December 12, 2013 Author Posted December 12, 2013 We read the disc number in the tags, we don't use the file names at all for that. you could try running your song through ffprobe to see what it reports because that's what we use. Sorry but I can't find the local path to ffprob.exe or variable to run the test on the file. Where would I find it?
Tikuf 663 Posted December 12, 2013 Posted December 12, 2013 (edited) %appdata%\MediaBrowser-Server\ffmpeg in the ffmpeg folder with the newest date Edited December 12, 2013 by Tikuf
Solution Tanamur 53 Posted December 12, 2013 Author Solution Posted December 12, 2013 Thanks Luke/Tikuf - (L)user error. A quick probe of the tracks did not reveal a "DISC:" field. Media Monkey (MM) does tagging a bit differently in that it stores all of the modifications in its own database and then requires you to Synchronize (write) the MM database to the file tags explicitly. I am sure this is a good thing as a double check before user modification of the actual files. After syncronizing/writing the new tags and a quick MB3 rescan of the files I get this..... ...instead of this.... Many thanks gentlemen. Problem solved! RocknRoll, Tanamur
Brendon 128 Posted December 20, 2013 Posted December 20, 2013 How do we handle Album Boxsets?? I don't mean double/triple albums etc... specifically boxsets with multiple albums, i have several of these for Pink Floyd, The Beatles, ACDC, ABBA etc.... each album inside has a unique cover and it would be nice to have a way of displaying it like movie boxsets.
Luke 42288 Posted December 20, 2013 Posted December 20, 2013 that's not a supported feature right now, and unlike movie collections i'm not aware of any online sources for images and metadata
Brendon 128 Posted December 20, 2013 Posted December 20, 2013 (edited) awww but, but, luke i have my own images and will write the metadata lol was just hoping there was some work-around for them, i was having so much fun adding my .flac library now it's supported, i knew i would hit a wall somewhere because it was all too easy Edited December 20, 2013 by Brendon
Tolerant 74 Posted June 29, 2015 Posted June 29, 2015 that's not a supported feature right now, and unlike movie collections i'm not aware of any online sources for images and metadata MP3Tag (Software, Free) supports images and or metadata from Amazon.com / .de, and Musicbrainz.org, discogs.com, freeb. for Artists, Albums, etc. *Kind of old post, I know.
