Which Remote Controls work for MBT?
There are a ton fo media center remotes out there though since I have never used any, will all of them work or are there specific features I need to be looking for in a remote to work completly with MBT?
Well my suggestion on remotes is always a Logitech Harmony remote. And just pick the one that best fits your budget/needs.  They are all programmable so you can also make it work  :D.
  • Like 1
Thank you!
Do you know at all if Logitech remote will work with the Imon receivers? I don't have an imon receiver but I had an idea.
The Logitech Harmony remotes should work with any IR receivers including the iMon ones. Just make sure it is configured to emulate a MCE remote and all of the functions should work.
