1.1.70 Sets issue?
Go to solution Solved by Angelblue05,
I noticed this with previous versions as well. But when starting Kodi, emby starts, says it is syncing 5 items, then seems to run through my entire sets/collection list.
On opening the sets I have, I get no metadata about the movies included in the sets, This could be a Titan issue, but the view I am using works flawlessly for other movies and tv series and they don't seem to resync on every kodi startup.
Sounds like it is crashing.  Post a log please.
Finally got time to enable debug and start Kodi.
On this start Kodi emby started suggested there were 5 updates, worked on those updates, then carried on through updating my entire collection, or least suggested it on the screen as doing so.
emby-5updates-allcollections.7z
  • Solution
Angelblue05
Sets are set to sync if there's any movies added or updated. Unfortunately, the server doesn't send messages when boxsets are modified (at least not in a reliable way), so we are forced to do this. However it does not modify anything if there's nothing to modify. It simply does a quick compare. The api from emby is pretty limited in this area. There's no way of knowing if the item belongs to a boxset or not.
Sets do not have metadata in Kodi. They are a mere grouping function, to which we can assign artwork. Maybe you can take a screenshot of what you are talking about if that doesn't answer your issue.
Edited by Angelblue05
That sounds like a good enough answer to me, just haven't noticed it before the recent betas 1.1.6x.
Thanks
Guest
