switch from remote mysql library
farfromrefuge
Hi,
I am trying to test emby but i am facing an issue. Right now i am using a remote sql database hosted on my NAS.
I see that you don't support that and i get why.
But do you know how to switch to local database? By that i obviously mean without loosing what in my database ;)
THanks
1. Scan you library into Emby Server and make sure you are happy with the scan results
2. Sync all your Kodi play states using Trakt for Kodi
3. Sync your playstates to Emby server using Trakt for Emby Server
4. Uninstall the linkage to the MySQL database from Kodi (and probably back it up just in case)
5. Uninstall/disable Trakt for Kodi
6. Install Emby for Kodi addon and sync
7. If things don't look right, try a database reset from Video->Video Addons->Emby...(hopefully not needed)
Edited by xnappo
farfromrefuge
Ok first got trakt synced and synced with emby: working great!
Now i have a problem with the kodi sync.
I use a nightly build of kodi and emby tells me my database won't sync because it's not compatible yet.
Is there a way to disable that check for now?
THanks
Nope - the Kodi team changes the database constantly in nightlies.  We can only support release candidates and releases as that is where the DB is stable.
If you are up to hacking to code yourself, you can give it a go, but i is a moving target and will only cause frustration :)
Unofficially we try to keep up with betas - but it is not supported so do not complain if a beta doesn't work.
xnappo
Edited by xnappo
farfromrefuge
I don't complain at all :D
I just want to try it.
No worry i will hack the plugin and remove the check.
Thanks for your help
Guest
