Teddy 100 Posted January 3, 2016 Posted January 3, 2016 (edited) Luke , from version 3.0.5781.6 (including last version 3.0.5800.3) the search option does not work but I worked well with versions 3.0.5781.5 and previous one.When I put the cursor over the options is not automatically deploys as before and when to use the find option goes black. The behavior is the same with IE and with other remote machines using Web client. I think it will be easier to see the attached movie behavior speak. PD. Please fix when you can, include special characters in search. Edited January 8, 2016 by Teddy
Luke 42241 Posted May 24, 2016 Posted May 24, 2016 It is the same for me. DId you solve? Hi, welcome. This issue is from January. Please start over and report your issue by seeing how to report a problem. Thanks!
