strohj 0 Posted December 12, 2013 Posted December 12, 2013 HI, I am using MB Classic version 3.0.100.0 B12-4.1 with the default theme VLC version 2.1.2 32bit MB server version 3.0.5083.27698 when i play a movie in vlc everything works fine until the movie is over at which time vlc closes, but i am left on my desktop, when i cilck on the media center icon in my task bar, I get the message saying that mediabrowser encountered a error and must close. the .NET error listed in event viewer is : .NET Runtime version 4.0.30319.34003 - There was a failure initializing profiling API attach infrastructure. This process will not allow a profiler to attach. HRESULT: 0x80004005. Process ID (decimal): 2936. Message ID: [0x2509]. I had the following in the media browser logs folder, but the file was dated from yesterday when i was testing to see if it played:; ffmpeg version N-58015-g8cdf4e0 Copyright © 2000-2013 the FFmpeg developers built on Nov 10 2013 18:01:44 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib libavutil 52. 52.100 / 52. 52.100 libavcodec 55. 41.100 / 55. 41.100 libavformat 55. 21.100 / 55. 21.100 libavdevice 55. 5.100 / 55. 5.100 libavfilter 3. 90.102 / 3. 90.102 libswscale 2. 5.101 / 2. 5.101 libswresample 0. 17.104 / 0. 17.104 libpostproc 52. 3.100 / 52. 3.100 Input #0, matroska,webm, from 'file:\\RT-AC66U\My_Book\Movies\Family, The (2013) [PublicHD]\The Family (2013).mkv': Duration: 01:51:33.57, start: 0.000000, bitrate: 9799 kb/s Chapter #0.0: start 0.000000, end 386.720000 Metadata: title : 00:00:00.000 Chapter #0.1: start 386.720000, end 597.430000 Metadata: title : 00:06:26.720 Chapter #0.2: start 597.430000, end 803.636000 Metadata: title : 00:09:57.430 Chapter #0.3: start 803.636000, end 1030.947000 Metadata: title : 00:13:23.636 Chapter #0.4: start 1030.947000, end 1328.494000 Metadata: title : 00:17:10.947 Chapter #0.5: start 1328.494000, end 1666.081000 Metadata: title : 00:22:08.494 Chapter #0.6: start 1666.081000, end 1906.822000 Metadata: title : 00:27:46.081 Chapter #0.7: start 1906.822000, end 2216.256000 Metadata: title : 00:31:46.822 Chapter #0.8: start 2216.256000, end 2572.737000 Metadata: title : 00:36:56.256 Chapter #0.9: start 2572.737000, end 2710.207000 Metadata: title : 00:42:52.737 Chapter #0.10: start 2710.207000, end 3257.171000 Metadata: title : 00:45:10.207 Chapter #0.11: start 3257.171000, end 3513.093000 Metadata: title : 00:54:17.171 Chapter #0.12: start 3513.093000, end 3741.988000 Metadata: title : 00:58:33.093 Chapter #0.13: start 3741.988000, end 3870.033000 Metadata: title : 01:02:21.988 Chapter #0.14: start 3870.033000, end 4031.945000 Metadata: title : 01:04:30.033 Chapter #0.15: start 4031.945000, end 4379.125000 Metadata: title : 01:07:11.945 Chapter #0.16: start 4379.125000, end 4645.266000 Metadata: title : 01:12:59.125 Chapter #0.17: start 4645.266000, end 5100.095000 Metadata: title : 01:17:25.266 Chapter #0.18: start 5100.095000, end 5282.819000 Metadata: title : 01:25:00.095 Chapter #0.19: start 5282.819000, end 5465.627000 Metadata: title : 01:28:02.819 Chapter #0.20: start 5465.627000, end 5711.122000 Metadata: title : 01:31:05.627 Chapter #0.21: start 5711.122000, end 6254.874000 Metadata: title : 01:35:11.122 Chapter #0.22: start 6254.874000, end 6317.102000 Metadata: title : 01:44:14.874 Chapter #0.23: start 6317.102000, end 6693.573000 Metadata: title : 01:45:17.102 Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x808, SAR 1:1 DAR 240:101, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default) Stream #0:2(eng): Subtitle: subrip [libx264 @ 04240020] using SAR=1/1 [libx264 @ 04240020] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 [libx264 @ 04240020] profile High, level 4.0 Output #0, mpegts, to 'C:\Users\strohj\AppData\Roaming\MediaBrowser-Server\cache\encoded-media\d266a649-ce8c-f3c3-e3f8-633de4ab9118.ts': Metadata: encoder : Lavf55.21.100 Chapter #0.0: start 0.000000, end 386.720000 Metadata: title : 00:00:00.000 Chapter #0.1: start 386.720000, end 597.430000 Metadata: title : 00:06:26.720 Chapter #0.2: start 597.430000, end 803.636000 Metadata: title : 00:09:57.430 Chapter #0.3: start 803.636000, end 1030.947000 Metadata: title : 00:13:23.636 Chapter #0.4: start 1030.947000, end 1328.494000 Metadata: title : 00:17:10.947 Chapter #0.5: start 1328.494000, end 1666.081000 Metadata: title : 00:22:08.494 Chapter #0.6: start 1666.081000, end 1906.822000 Metadata: title : 00:27:46.081 Chapter #0.7: start 1906.822000, end 2216.256000 Metadata: title : 00:31:46.822 Chapter #0.8: start 2216.256000, end 2572.737000 Metadata: title : 00:36:56.256 Chapter #0.9: start 2572.737000, end 2710.207000 Metadata: title : 00:42:52.737 Chapter #0.10: start 2710.207000, end 3257.171000 Metadata: title : 00:45:10.207 Chapter #0.11: start 3257.171000, end 3513.093000 Metadata: title : 00:54:17.171 Chapter #0.12: start 3513.093000, end 3741.988000 Metadata: title : 00:58:33.093 Chapter #0.13: start 3741.988000, end 3870.033000 Metadata: title : 01:02:21.988 Chapter #0.14: start 3870.033000, end 4031.945000 Metadata: title : 01:04:30.033 Chapter #0.15: start 4031.945000, end 4379.125000 Metadata: title : 01:07:11.945 Chapter #0.16: start 4379.125000, end 4645.266000 Metadata: title : 01:12:59.125 Chapter #0.17: start 4645.266000, end 5100.095000 Metadata: title : 01:17:25.266 Chapter #0.18: start 5100.095000, end 5282.819000 Metadata: title : 01:25:00.095 Chapter #0.19: start 5282.819000, end 5465.627000 Metadata: title : 01:28:02.819 Chapter #0.20: start 5465.627000, end 5711.122000 Metadata: title : 01:31:05.627 Chapter #0.21: start 5711.122000, end 6254.874000 Metadata: title : 01:35:11.122 Chapter #0.22: start 6254.874000, end 6317.102000 Metadata: title : 01:44:14.874 Chapter #0.23: start 6317.102000, end 6693.573000 Metadata: title : 01:45:17.102 Stream #0:0(eng): Video: h264 (libx264), yuv420p, 1920x808 [sAR 1:1 DAR 240:101], q=-1--1, 9799 kb/s, 90k tbn, 23.98 tbc (default) Stream #0:1(eng): Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp, 1536 kb/s (default) Stream mapping: Stream #0:0 -> #0:0 (h264 -> libx264) Stream #0:1 -> #0:1 (dca -> libmp3lame) Press [q] to stop, [?] for help frame= 46 fps=0.0 q=0.0 size= 177kB time=00:00:01.96 bitrate= 737.4kbits/s frame= 56 fps= 54 q=0.0 size= 2069kB time=00:00:02.47 bitrate=6855.2kbits/s frame= 66 fps= 43 q=13.0 size= 5814kB time=00:00:02.80 bitrate=16961.4kbits/s frame= 82 fps= 40 q=20.0 size= 7632kB time=00:00:03.50 bitrate=17842.1kbits/s frame= 110 fps= 43 q=19.0 size= 8759kB time=00:00:04.70 bitrate=15252.5kbits/s frame= 136 fps= 44 q=15.0 size= 9316kB time=00:00:05.73 bitrate=13304.9kbits/s frame= 154 fps= 43 q=18.0 size= 10358kB time=00:00:06.50 bitrate=13045.5kbits/s frame= 169 fps= 42 q=19.0 size= 11604kB time=00:00:07.17 bitrate=13246.9kbits/s frame= 185 fps= 40 q=19.0 size= 12652kB time=00:00:07.77 bitrate=13328.4kbits/s frame= 199 fps= 39 q=20.0 size= 13597kB time=00:00:08.35 bitrate=13336.2kbits/s frame= 211 fps= 38 q=21.0 size= 14497kB time=00:00:08.92 bitrate=13301.3kbits/s frame= 226 fps= 37 q=22.0 size= 15588kB time=00:00:09.48 bitrate=13470.3kbits/s frame= 238 fps= 36 q=25.0 size= 16659kB time=00:00:09.98 bitrate=13668.8kbits/s frame= 250 fps= 35 q=26.0 size= 18113kB time=00:00:10.48 bitrate=14147.7kbits/s frame= 262 fps= 34 q=25.0 size= 19203kB time=00:00:11.01 bitrate=14280.3kbits/s frame= 279 fps= 34 q=25.0 size= 20286kB time=00:00:11.68 bitrate=14218.3kbits/s frame= 293 fps= 34 q=27.0 size= 20981kB time=00:00:12.28 bitrate=13987.1kbits/s frame= 312 fps= 34 q=24.0 size= 21775kB time=00:00:13.05 bitrate=13662.6kbits/s frame= 328 fps= 34 q=23.0 size= 22313kB time=00:00:13.80 bitrate=13245.3kbits/s frame= 347 fps= 34 q=25.0 size= 22885kB time=00:00:14.59 bitrate=12847.6kbits/s frame= 365 fps= 34 q=25.0 size= 23429kB time=00:00:15.26 bitrate=12574.0kbits/s frame= 385 fps= 34 q=23.0 size= 24069kB time=00:00:16.12 bitrate=12225.4kbits/s frame= 405 fps= 34 q=22.0 size= 24577kB time=00:00:16.99 bitrate=11848.5kbits/s frame= 426 fps= 35 q=23.0 size= 25130kB time=00:00:17.85 bitrate=11529.3kbits/s frame= 459 fps= 36 q=14.0 size= 25661kB time=00:00:19.22 bitrate=10935.0kbits/s frame= 487 fps= 37 q=20.0 size= 26366kB time=00:00:20.40 bitrate=10587.9kbits/s frame= 506 fps= 37 q=19.0 size= 27220kB time=00:00:21.24 bitrate=10498.2kbits/s frame= 525 fps= 37 q=18.0 size= 28074kB time=00:00:22.10 bitrate=10404.6kbits/s frame= 543 fps= 37 q=20.0 size= 28959kB time=00:00:22.70 bitrate=10448.8kbits/s frame= 560 fps= 37 q=20.0 size= 29798kB time=00:00:23.54 bitrate=10367.9kbits/s frame= 579 fps= 37 q=20.0 size= 30762kB time=00:00:24.24 bitrate=10396.2kbits/s frame= 595 fps= 37 q=20.0 size= 31599kB time=00:00:24.93 bitrate=10380.7kbits/s frame= 614 fps= 36 q=19.0 size= 32720kB time=00:00:25.77 bitrate=10398.7kbits/s frame= 631 fps= 36 q=20.0 size= 33609kB time=00:00:26.42 bitrate=10419.3kbits/s frame= 650 fps= 36 q=19.0 size= 34559kB time=00:00:27.21 bitrate=10402.1kbits/s frame= 667 fps= 36 q=20.0 size= 35532kB time=00:00:27.91 bitrate=10428.4kbits/s frame= 683 fps= 36 q=20.0 size= 36430kB time=00:00:28.75 bitrate=10379.7kbits/s frame= 698 fps= 36 q=20.0 size= 37363kB time=00:00:29.18 bitrate=10487.9kbits/s frame= 713 fps= 36 q=20.0 size= 38541kB time=00:00:29.78 bitrate=10600.6kbits/s frame= 728 fps= 36 q=20.0 size= 39702kB time=00:00:30.45 bitrate=10679.0kbits/s
strohj 0 Posted December 13, 2013 Author Posted December 13, 2013 I am using the default theme (no other themes are even installed)
Solution Luke 42239 Posted December 13, 2013 Solution Posted December 13, 2013 if you're using the vlc external player profile, try the generic one. 1
strohj 0 Posted December 13, 2013 Author Posted December 13, 2013 if you're using the vlc external player profile, try the generic one. That seems to work, but VLC remains open atfer the movie, I have to manually close it, then I get back into MBC after that. Can I add a switch to VLC to tell it to close after the movie is over automatically?
strohj 0 Posted December 13, 2013 Author Posted December 13, 2013 I found the switch to close VLC automatically........ Its in preferences under advanced options, for streaming, pick play and exit
Luke 42239 Posted December 14, 2013 Posted December 14, 2013 yea i think it might be time to either deprecate the vlc profile or label is as compatible only with versions
Jvtm 13 Posted February 1, 2014 Posted February 1, 2014 Hello All, Love the program but recently have been running into lots of issues. I migrated from MB2.XX to MB3. In MB3, I tried to add vlc as the external player by using the generic profile and entering the vlc program path. This consistently causes a crash in the configurator. i got so fed up i moved back to MB2.xx and now i get the same issue there. I am running win7 64 bit and VLC 2.1.2.0. has anyone encountered this or have any idea what the solution here might be? thanks!
