Jonz 11 Posted January 2, 2016 Posted January 2, 2016 Hi, Need your assistance to look thru the following transcoding logs. The first file is a MKV file and i have no idea why it is transcoding , i have also attached my tv dlna profile for reference in case it's due to some error in the profile {"Protocol":"File","Id":"58178c5708cfba85bb6c99f8c2ad7942","Path":"/Volumes/Media-2/Movie'zzz/Run All Night 2015 720p HC HDRip x264 AC3 TiTAN/Run All Night 2015 720p HC HDRip x264 AC3 TiTAN.mkv","Type":"Default","Container":"mkv","Name":"","RunTimeTicks":68580160000,"ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"Bitrate":2700363,"RequiredHttpHeaders":{}} /Users/Jonz/.config/emby-server/ffmpeg/20150917/ffmpeg -fflags +genpts -i file:"/Volumes/Media-2/Movie'zzz/Run All Night 2015 720p HC HDRip x264 AC3 TiTAN/Run All Night 2015 720p HC HDRip x264 AC3 TiTAN.mkv" -sn -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -vf "scale=trunc(min(max(iw\,ih*dar)\,min(1920\,1080*dar))/2)*2:trunc(min(max(iw/dar\,ih)\,min(1920/dar\,1080))/2)*2" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 29680000 -vsync vfr -level 51 -map_metadata -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 320000 -af "aresample=async=1" -y "/Volumes/Appz/transcoding-temp/7e3cc1caa0efb56ac742032a368ee4e3.ts" ffmpeg version N-75356-gf58e011-tessus Copyright © 2000-2015 the FFmpeg developers built with Apple LLVM version 6.0 (clang-600.0.57) (based on LLVM 3.5svn) configuration: --cc=/usr/bin/clang --prefix=/opt/ffmpeg --as=yasm --extra-version=tessus --enable-avisynth --enable-fontconfig --enable-gpl --enable-libass --enable-libbluray --enable-libfreetype --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopus --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzmq --enable-version3 --disable-ffplay --disable-indev=qtkit --disable-indev=x11grab_xcb libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 1.100 / 57. 1.100 libavformat 57. 0.100 / 57. 0.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 1.100 / 6. 1.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, matroska,webm, from 'file:/Volumes/Media-2/Movie'zzz/Run All Night 2015 720p HC HDRip x264 AC3 TiTAN/Run All Night 2015 720p HC HDRip x264 AC3 TiTAN.mkv': The second file i was having issues with is a HEVC X265 file and has anyone got any idea on how i can include HEVC x265 support into the DLNA profile. I have been getting errors when i try to edit the profile and include hevc x265. The LG TV i have definitely supports hevc x265 playback. {"Protocol":"File","Id":"39f5cc05c5eaa0945a456fdaa8942289","Path":"/Volumes/Media-2/Movie'zzz/Maze.Runner.The.Scorch.Trials.2015.720p.BRRiP.HEVC.x265.AC3-MAJESTIC/Maze.Runner.The.Scorch.Trials.2015.720p.BRRiP.HEVC.x265.AC3-MAJESTIC.mkv","Type":"Default","Container":"mkv","Name":"","ReadAtNativeFramerate":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"RequiresOpening":false,"RequiresClosing":false,"VideoType":"VideoFile","MediaStreams":[],"PlayableStreamFileNames":[],"Formats":[],"RequiredHttpHeaders":{}} /Users/Jonz/.config/emby-server/ffmpeg/20150917/ffmpeg -fflags +genpts -i file:"/Volumes/Media-2/Movie'zzz/Maze.Runner.The.Scorch.Trials.2015.720p.BRRiP.HEVC.x265.AC3-MAJESTIC/Maze.Runner.The.Scorch.Trials.2015.720p.BRRiP.HEVC.x265.AC3-MAJESTIC.mkv" -sn -codec:v:0 libx264 -force_key_frames expr:gte(t,n_forced*5) -vf "scale=trunc(min(max(iw\,ih*dar)\,min(1920\,1080*dar))/2)*2:trunc(min(max(iw/dar\,ih)\,min(1920/dar\,1080))/2)*2" -pix_fmt yuv420p -preset superfast -crf 23 -b:v 29680000 -vsync vfr -level 51 -map_metadata -1 -threads 0 -codec:a:0 ac3 -ac 6 -ab 320000 -af "aresample=async=1" -y "/Volumes/Appz/transcoding-temp/c74d064efca66c95f65d86b6bde1d5c7.ts" ffmpeg version N-75356-gf58e011-tessus Copyright © 2000-2015 the FFmpeg developers built with Apple LLVM version 6.0 (clang-600.0.57) (based on LLVM 3.5svn) configuration: --cc=/usr/bin/clang --prefix=/opt/ffmpeg --as=yasm --extra-version=tessus --enable-avisynth --enable-fontconfig --enable-gpl --enable-libass --enable-libbluray --enable-libfreetype --enable-libgsm --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopus --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzmq --enable-version3 --disable-ffplay --disable-indev=qtkit --disable-indev=x11grab_xcb libavutil 55. 2.100 / 55. 2.100 libavcodec 57. 1.100 / 57. 1.100 libavformat 57. 0.100 / 57. 0.100 libavdevice 57. 0.100 / 57. 0.100 libavfilter 6. 1.100 / 6. 1.100 libswscale 4. 0.100 / 4. 0.100 libswresample 2. 0.100 / 2. 0.100 libpostproc 54. 0.100 / 54. 0.100 Input #0, matroska,webm, from 'file:/Volumes/Media-2/Movie'zzz/Maze.Runner.The.Scorch.Trials.2015.720p.BRRiP.HEVC.x265.AC3-MAJESTIC/Maze.Runner.The.Scorch.Trials.2015.720p.BRRiP.HEVC.x265.AC3-MAJESTIC.mkv': Thank you and a Happy New Year to everyone. LG Smart+ TV.xml
Luke 42239 Posted January 2, 2016 Posted January 2, 2016 Looks like your first file is missing media info. Try refreshing from the detail screen of the web interface.
Jonz 11 Posted January 8, 2016 Author Posted January 8, 2016 Looks like your first file is missing media info. Try refreshing from the detail screen of the web interface. Your recommendation fixed that issue. Any ideas on the X265 codec part?
Happy2Play 9811 Posted January 8, 2016 Posted January 8, 2016 (edited) Have you tried adding hevc as your direct play mkv video codec? example from Windows 10 app <DirectPlayProfile container="mkv" audioCodec="aac,ac3,eac3,mp3,mp2,pcm,pcm_s16le,pcm_s24le" videoCodec="h264,hevc" type="Video" /> Edited January 8, 2016 by Happy2Play
Luke 42239 Posted June 20, 2016 Posted June 20, 2016 Hi, I am testing now with a 2015 LG with the latest beta Emby Server, and both Dlna Play To and the Dlna Server are working out of the box with no problems. Please try again. Thanks.
