nickname 0 Posted January 1, 2016 Posted January 1, 2016 i used to see nice images from my collection, but the last weeks they keep dissapearing. if i delete them they show up for a while but change back to ugly ones https://onedrive.live.com/redir?resid=9E3D7D98DF57553A!1998&authkey=!AAQx5nJi3J4kXLs&v=3&ithint=photo%2cPNG is there a fix for this ?
Luke 42185 Posted January 2, 2016 Posted January 2, 2016 where did you change them, under library setup?
nickname 0 Posted January 7, 2016 Author Posted January 7, 2016 yes i tried under library setup and under metadata manager and if you hover over the image it pops up a menu with edit image they keep changing back
nickname 0 Posted January 11, 2016 Author Posted January 11, 2016 anyone? i tried everything removed the libarys reboot then added again, dosnt matter images are not saved
Happy2Play 9800 Posted January 11, 2016 Posted January 11, 2016 You need to upload the images you want under Library, and then delete the images found on My Media (These are cached images). Then the Images you uploaded via Library will propagate to My Media.
nickname 0 Posted January 11, 2016 Author Posted January 11, 2016 okay, but why dos emby create them in the first place then ? https://onedrive.live.com/redir?resid=9E3D7D98DF57553A!2119&authkey=!AG_B8f3l6bMGWEo&v=3&ithint=photo%2cPNG i am sure it worked for months before
speechles 2061 Posted January 11, 2016 Posted January 11, 2016 http://emby.media/community/index.php?/topic/29527-How-to-keep-split-sliced-mosaic-tiles?&do=findComment&comment=283103 I think he means this. Sent from my Nexus 7 using Tapatalk
