keem85 6 Posted December 31, 2015 Posted December 31, 2015 (edited) I have used Emby with success for two days now.. Suddenly I cannot see my content.. In "Library" I can see my content fine, and adding new contents without problem, but they never show up when I am to watch them!! Take a look at this screenshot: http://imgur.com/PaQUg0J Why is there nothing there? EDIT (Side question): How do I re-scrape my contents? Edited December 31, 2015 by keem85
genesisforlive 7 Posted December 31, 2015 Posted December 31, 2015 Check your metadata, and make a screen
Happy2Play 9800 Posted December 31, 2015 Posted December 31, 2015 What happens if you do a library scan? Dashboard - Scheduled Task - Run a Library Scan
keem85 6 Posted January 1, 2016 Author Posted January 1, 2016 What happens if you do a library scan? Dashboard - Scheduled Task - Run a Library Scan Hi folks, thanks for your answers. I did a library scan, restarted and now they are back again. But still sometimes they disappear like I'm showing on the picture there. But that can be related to Google Chrome maybe(?)
Spaceboy 2573 Posted January 1, 2016 Posted January 1, 2016 I have noticed that since the library scan changes were implemented a couple of months ago that when the scan is running I sometimes see this same issue. But I'm running the dev version so just hoped it was something that would be ironed out at some point
chef 3811 Posted January 1, 2016 Posted January 1, 2016 That definitely happens during a media scan. I have found that during an initial scan (which can take quite a while to complete) the libraries will disappear from the slide out menu. I figure it is because emby is building them. However each scan after the initial one is very fast, and you'll probably find that you won't notice those libraries disappearing.
Spaceboy 2573 Posted January 3, 2016 Posted January 3, 2016 That definitely happens during a media scan. I have found that during an initial scan (which can take quite a while to complete) the libraries will disappear from the slide out menu. I figure it is because emby is building them. However each scan after the initial one is very fast, and you'll probably find that you won't notice those libraries disappearing. well maybe something is wrong for me too then because i cannot agree that subsequent scans are very fast, mine just finished one that took 2hours 22mins. there is virtually no cpu activity the whole time and emby mostly seems to behave fine but i do see occasional things such as this
