cmcg 876 Posted January 7, 2016 Author Posted January 7, 2016 This might be a stupid question, but does this and the SD-version share code-base? Like, are the same things fixed, and new features added, in both at the same time, so it is only the resolution and the size of images that changes? Yes, at the moment the code base is mostly the same. That's why the version numbers are similar. 1.0.4 = 2.0.4 in bug fixes for things other than the user interface, like subtitles. The difference is that not only does 2.x have higher resolution but it no longer has the limitation of supporting D-Series. So we can now add HTML5 and CSS3 features that we could not before. The animated DVD disk for instance. 1
cmcg 876 Posted January 7, 2016 Author Posted January 7, 2016 Hey Just installed this on my H-series. It is looking beautiful! It does lag a lot, though, but that must be all the waiting for higher resolution images or something. I don't really understand why my TV generally has such bad performance (it's also a bit laggy in some of the native menus), when it has a quad-core processor. That being said, it looks like whenever I switch up/down in the 3-row-views, so a new row becomes visible, it reloads ALL the images, and not just the ones for the new row. It takes about a second to load a new row because of this, and it looks...not good. I can't remember if it was like this in the SD version, or if I just didn't notice because the images were smaller, so it went quicker. It seems like a waste of bandwidth and processing power, to reload everything for each row change. EDIT: Yeah, SD version does that as well. Much more evident, dealying and annoying on the HD version. Even without it changing rows, it takes about 500-1000ms to move from one title to the next. That's unbearable, so I will be going back to the SD version. Beautiful work on the app, though! It looks fantastic! Your server is generating and caching new, bigger versions of every image. It gets better after you've spent a little time with it. However, the performance is not as smooth as the lower resolution. I am trying to limit the load on the TV processor and learn to work with it the best we can. 3
Ultroman 89 Posted January 7, 2016 Posted January 7, 2016 Thanks for that explanation. Any idea why it is running so poorly on my H-series? Is that just the way it is for everyone on H-series?
cmcg 876 Posted January 7, 2016 Author Posted January 7, 2016 Thanks for that explanation. Any idea why it is running so poorly on my H-series? Is that just the way it is for everyone on H-series? If your timings are accurate then it's much worse than my F-Series where the lag is hardly noticeable. All I see if a slight jagging if it's doing more than one thing at the same time (which I can code out) and the menu open/close is a bit abrupt.
Ultroman 89 Posted January 7, 2016 Posted January 7, 2016 If your timings are accurate then it's much worse than my F-Series where the lag is hardly noticeable. All I see if a slight jagging if it's doing more than one thing at the same time (which I can code out) and the menu open/close is a bit abrupt.That sounds like how the SD version runs on my H-series. I gotta read up on performance problems with my TVs. They're both H-series, and run the HD version very, very sluggishly.
sh0rty 727 Posted January 8, 2016 Posted January 8, 2016 That sounds like how the SD version runs on my H-series. I gotta read up on performance problems with my TVs. They're both H-series, and run the HD version very, very sluggishly. The more the HD version is used, the better it gets. Also know what you mean. Even the Smart Hub on my TV is sluggish. The general UI handling is not well done by Samsung, and since smart hub update it's worse. Gesendet von meinem HTC One M8 mit Tapatalk
FrostByte 5452 Posted January 8, 2016 Posted January 8, 2016 (edited) I noticed mine was a little slower tonight after I installed the cover art plugin. It was really really slow the first time I went through my collections and got better the second time through after it had cached the images, but it still felt slower than before I added the plugin. I thought everything was fairly quick before the plugin since cmcg added that change of the menu Edited January 8, 2016 by FrostByte
SamES 1084 Posted January 8, 2016 Posted January 8, 2016 I'm using the E-Series without an Evolution kit, so it only has the Dual Core processor. I've not noticed it to be much slower than the non-1080 version, (maybe that's because it was always slow in comparison to the Quad cores and the extra overhead of pulling hi-res images from the server is negligible). Having said that, it is definitely usable without causing a bad user experience, so I'm surprised that you are having such a bad performance on the F-Series. This makes me think the issue is not the TV performance but more likely the server struggling to remake the images? There is no way I would consider going back on this model (and loose the spinning disc!)
FrostByte 5452 Posted January 8, 2016 Posted January 8, 2016 There is no way I would consider going back on this model (and loose the spinning disc!) Lol, the only reason I loaded the CA plugin was because of the disc. It just didn't look right popping out of a plain poster 1
cmcg 876 Posted January 8, 2016 Author Posted January 8, 2016 (edited) 2.0.5bNew media icons for 3D Side-by-Side and 3D Top-and-Bottom.Correct 16:9 media icon now used.Fixed: 3D media icon displayed twice.Fixed: Spinning disk appears before the cover art.Fixed: Subtitles truncating letters when text ends with a newline.Episode details page now shows correct season poster. These changes are mostly the same as 1.0.5 except for a little subtitle fix that was already in the SD version and a tweak to the timing of the backdrops and spinning disk on the item details page that makes it a little smoother and avoids the disk appearing before the poster. Edited January 8, 2016 by cmcg 5
FrostByte 5452 Posted January 8, 2016 Posted January 8, 2016 Looks good sir, another great job. Movie description pages seem to load a lot smoother now 2
Ultroman 89 Posted January 8, 2016 Posted January 8, 2016 It's the H-series which are apparently slow. I have quite a powerful server, but only 100mbit switches. But then, my TVs only have 100mbit, unless I am much mistaken.
sh0rty 727 Posted January 9, 2016 Posted January 9, 2016 It's the H-series which are apparently slow. I have quite a powerful server, but only 100mbit switches. But then, my TVs only have 100mbit, unless I am much mistaken. Isn't the latest version much more fluid on you device?
fc7 123 Posted January 12, 2016 Posted January 12, 2016 (edited) The more the HD version is used, the better it gets. Also know what you mean. Even the Smart Hub on my TV is sluggish. The general UI handling is not well done by Samsung, and since smart hub update it's worse. Gesendet von meinem HTC One M8 mit Tapatalk Same here........even native samsung menues are a little bit laggy.Probable is just the H's firmware or something. The HD app is absolutely usable for me. I'm not going back to the sd version. No fu......ing way. Sent from my iPad using Tapatalk Edited January 12, 2016 by fc7 4
SilentAssassin 96 Posted January 13, 2016 Posted January 13, 2016 I think someone has mentioned it but the OSD during playback is messed when watching a 3D movie, it's like it is twice the size it should be.
sh0rty 727 Posted January 13, 2016 Posted January 13, 2016 I think someone has mentioned it but the OSD during playback is messed when watching a 3D movie, it's like it is twice the size it should be. That's new to me I just have it invisible (H-TAB) or in correct position (H-SBS)
cmcg 876 Posted January 20, 2016 Author Posted January 20, 2016 (edited) 2.0.6Show missing icon on the home page.Fixed: Hang when pressing play on missing items on the home page.Settings page style updated.Player tools menu style updated.Fixed: Italic subtitle size set incorrectly. Fixed a few of your bug reports here and improved some of the UI. I think we'll drop the beta tag. 2.x is no less stable than 1.x. We'll move 2.x to the stable thread soon, but I'd quite like to still offer the 1.x version for D series users. Does anyone have a webserver with a (reasonably) static IP address that it could live on? Edited January 20, 2016 by cmcg 4
FrostByte 5452 Posted January 20, 2016 Posted January 20, 2016 I like the rounded edges in the app settings pages Btw: did the server IP page recently just go to 1080P? The box is really small and almost hard to see the number you type in the boxes. Don't recall them being that small in 2.0.5
cmcg 876 Posted January 20, 2016 Author Posted January 20, 2016 No, can you attach a screenshot. There was no change to that page this release.
FrostByte 5452 Posted January 20, 2016 Posted January 20, 2016 The pic has a glare from the window so you can't see the text. I was like 2 feet away from the tv, so the box doesn't look that small from this distance. I just know I can barely read it form my couch any more it's so small. Not a biggie, I can live with it. Thanks
cmcg 876 Posted January 20, 2016 Author Posted January 20, 2016 Oh yes, I see now. It's to do with the way that I changed inheritance of font sizes when fixing the italic subtitle size bug. I'll have to make a change there in the next update. Thanks for the heads up. 1
cmcg 876 Posted January 20, 2016 Author Posted January 20, 2016 Looks like that font size bug will show up in quite a few places. Search, Add To Playlist, Upcoming TV. I'll start a thread... 1
cmcg 876 Posted January 23, 2016 Author Posted January 23, 2016 2.0.7Note: this release will reset your settings file.Latest Movies and TV views now respect the user home page setting "Hide watched content from latest media".Fixed: Some Font Sizes Much Smaller After 2.0.6 Update Fixed: TV/Movie genre posters too small.Fixed: TV/Movie poster image cropped in OSD. 3
FrostByte 5452 Posted January 23, 2016 Posted January 23, 2016 2.0.7 Latest Movies and TV views now respect the user home page setting "Hide watched content from latest media". Any chance of getting this added to the Server Settings page also? Thanks
FrostByte 5452 Posted January 23, 2016 Posted January 23, 2016 Everything seems to be running good here. Thanks for update cmcg
