CBers 7554 Posted January 5, 2016 Posted January 5, 2016 In the system.xml file where the MetadataOptions start there is an ItemType of "Episode" that I changed the MinWidth of Backdrops to 1920. That one isn't in the dashboard as an option to change. Actually, I went ahead and changed everything that said 1280 to 1920 in that file. Ta
cmcg 876 Posted January 6, 2016 Author Posted January 6, 2016 2.0.5aTidy up of index.html. Only HTML5 capable devices are now supported.Possible fix for installation issues on some Blu-ray Disk players.Disk art rotates while it pops up. (Yeah baby!)Backdrop changes delayed to improve performance.Media icons limited to six.Fixed: Whole screen shifts up on long playlists and during playback. 4
sh0rty 727 Posted January 6, 2016 Posted January 6, 2016 Screen shifting gone and no third row of media icons. Only cosmetical, but the 3D icon is still shown 2 times instead of Video codec and resolution. In 2D files it looks good. PS. My wife just asked why the disks do not spin permanently, no kidding! 2
cmcg 876 Posted January 6, 2016 Author Posted January 6, 2016 Yes, it's picking up the 3D icon when looking for the resolution. I'll try to replicate that later.
sh0rty 727 Posted January 6, 2016 Posted January 6, 2016 (edited) Yes, it's picking up the 3D icon when looking for the resolution. I'll try to replicate that later. Got a PM Should I do a SBS and TAB icon for MediaInfo so it can replace the resolution. I think the 3D format is in this case more interesting than the resolution. Edited January 6, 2016 by shorty1483
FrostByte 5452 Posted January 6, 2016 Posted January 6, 2016 Can you just get rid of the 3D icon then and just have HSBS, HTAB, etc icons
FrostByte 5452 Posted January 6, 2016 Posted January 6, 2016 (edited) 2.0.5a Disk art rotates while it pops up. (Yeah baby!) Superb, much better than that constant spinning disc pic Edited January 6, 2016 by FrostByte 2
sh0rty 727 Posted January 6, 2016 Posted January 6, 2016 (edited) Superb, much better than that constant spinning disc pic I hate you all, and my wife too !! What about these ones: Side effect: They are simple to understand and cover Half and Full SBS/TAB stuff. I like the ones without the 3D most. Clean and simple. Edited January 6, 2016 by shorty1483 1
FrostByte 5452 Posted January 6, 2016 Posted January 6, 2016 What about these ones: Side effect: They are simple to understand and cover Half and Full SBS/TAB stuff. I like the ones without the 3D most. Clean and simple. How hard would it be to make ones like 2 & 4, but with the 3D in the middle and still be able to clearly see which one it was? Just curious to see how that would look
CBers 7554 Posted January 6, 2016 Posted January 6, 2016 I hate you all, and my wife too !! What about these ones: Side effect: They are simple to understand and cover Half and Full SBS/TAB stuff. I like the ones without the 3D most. Clean and simple. You'll need all depending on the format of the 3D movie won't you?
sh0rty 727 Posted January 6, 2016 Posted January 6, 2016 How hard would it be to make ones like 2 & 4, but with the 3D in the middle and still be able to clearly see which one it was? Just curious to see how that would lookWill try tomorrow morning, bedtime now...[emoji6] Gesendet von meinem HTC One M8 mit Tapatalk 1
sh0rty 727 Posted January 6, 2016 Posted January 6, 2016 You'll need all depending on the format of the 3D movie won't you?Yes Gesendet von meinem HTC One M8 mit Tapatalk
SamES 1084 Posted January 6, 2016 Posted January 6, 2016 I've noticed that often the spinning disc loads before the cover has loaded which looks a bit odd. I'm not sure if this is a delay while cover-art applies treatment, or just a slow response from the server. I won't raise it as a bug, but it would be nice if it was possible to make sure the cover loaded before the disc, or the disc was hidden until the cover has loaded. Not a big issue either way. 1
cmcg 876 Posted January 6, 2016 Author Posted January 6, 2016 I've noticed that often the spinning disc loads before the cover has loaded which looks a bit odd. I'm not sure if this is a delay while cover-art applies treatment, or just a slow response from the server. I won't raise it as a bug, but it would be nice if it was possible to make sure the cover loaded before the disc, or the disc was hidden until the cover has loaded. Not a big issue either way. Done. Half second delay added in next beta. It's only noticeable on movies the first time you enter the details page while the server generates the images at the new higher resolution. 2
SamES 1084 Posted January 7, 2016 Posted January 7, 2016 Done. Half second delay added in next beta. It's only noticeable on movies the first time you enter the details page while the server generates the images at the new higher resolution. Thanks
gogreenpower 26 Posted January 7, 2016 Posted January 7, 2016 A totally non productive post but I've been away for 6 weeks and I can't wait to give this a try on my H series. Loving your work Green. 3
sh0rty 727 Posted January 7, 2016 Posted January 7, 2016 (edited) How hard would it be to make ones like 2 & 4, but with the 3D in the middle and still be able to clearly see which one it was? Just curious to see how that would look Next attempt....erm @@cmcg is it even possible to set that icons? Forgot to ask Edited January 7, 2016 by shorty1483 1
cmcg 876 Posted January 7, 2016 Author Posted January 7, 2016 Yup. Should be fine. Can I have them in 1080p and 960x540 versions please?
sh0rty 727 Posted January 7, 2016 Posted January 7, 2016 Yup. Should be fine. Can I have them in 1080p and 960x540 versions please? 3D.zip 1
cmcg 876 Posted January 7, 2016 Author Posted January 7, 2016 Done. @@shorty1483 One more request. Would it be possible for aspect_178.png to just say 16:9 instead? I think people are more familiar with what that means. 1
sh0rty 727 Posted January 7, 2016 Posted January 7, 2016 @@shorty1483 One more request. Would it be possible for aspect_178.png to just say 16:9 instead? I think people are more familiar with what that means. It's already included in the GDrive linked zip I sent you on 13th Nov. It's called widescreen.png
Ultroman 89 Posted January 7, 2016 Posted January 7, 2016 This might be a stupid question, but does this and the SD-version share code-base? Like, are the same things fixed, and new features added, in both at the same time, so it is only the resolution and the size of images that changes? 2
Ultroman 89 Posted January 7, 2016 Posted January 7, 2016 (edited) Hey Just installed this on my H-series. It is looking beautiful! It does lag a lot, though, but that must be all the waiting for higher resolution images or something. I don't really understand why my TV generally has such bad performance (it's also a bit laggy in some of the native menus), when it has a quad-core processor. That being said, it looks like whenever I switch up/down in the 3-row-views, so a new row becomes visible, it reloads ALL the images, and not just the ones for the new row. It takes about a second to load a new row because of this, and it looks...not good. I can't remember if it was like this in the SD version, or if I just didn't notice because the images were smaller, so it went quicker. It seems like a waste of bandwidth and processing power, to reload everything for each row change. EDIT: Yeah, SD version does that as well. Much more evident, dealying and annoying on the HD version. Even without it changing rows, it takes about 500-1000ms to move from one title to the next. That's unbearable, so I will be going back to the SD version. Beautiful work on the app, though! It looks fantastic! Edited January 7, 2016 by Ultroman
cmcg 876 Posted January 7, 2016 Author Posted January 7, 2016 It's already included in the GDrive linked zip I sent you on 13th Nov. It's called widescreen.png So it is. I'll blame Chess for that I think 1
