cmcg 876 Posted December 31, 2015 Author Posted December 31, 2015 That's just backdrops again. I'm talking about extracted episode images.
FrostByte 5453 Posted December 31, 2015 Posted December 31, 2015 Ahh...makes sense now However, for some reason I can't find that one in the dashboard. It's not listed as an option you can change under episodes in dashboard so I changed mine in the xml 1
sh0rty 727 Posted January 2, 2016 Posted January 2, 2016 Happy new year! The OSD and Tools Menu reacts kind of weird when playing a 3D MKV (HSBS/HTAB). Most of the time, it doesn't show at all when pressing Info or Tools, but when it shows, the menu looks not normal. In old version it went well. Cheers
SamES 1084 Posted January 3, 2016 Posted January 3, 2016 OK,so I ignored the warnings and loaded this up on my ES8000. Works fine, except for the already identified issues with box-shadow and cover-art, and the stuttering of the side menu when it opens. Otherwise, at least on this model, 1080p seems fine for E-Series. Thanks @@cmcg 1
cmcg 876 Posted January 3, 2016 Author Posted January 3, 2016 OK,so I ignored the warnings and loaded this up on my ES8000. Works fine, except for the already identified issues with box-shadow and cover-art, and the stuttering of the side menu when it opens. Otherwise, at least on this model, 1080p seems fine for E-Series. Thanks @@cmcg Hey @@SamES , I was hoping you'd ignore my warning! Thanks very much for your testing. I really didn't know if 1080p could work on E-Series. I'll update the first post to reflect this and other E-Series owners can give it a go.
deadnex 6 Posted January 3, 2016 Posted January 3, 2016 (edited) I have tested this version on my UE65JS8505 (Tizen), but is has the same problem that I experienced on the 1.0.x builds. The screen where you are supposed to enter server ip/address only displays a grey screen. I am currently running Emby for Samsung v.0.593 without any major issues, but it would be nice to find out what has changed in the newer builds causing them to fail to load on Tizen. Edited January 3, 2016 by deadnex
cmcg 876 Posted January 3, 2016 Author Posted January 3, 2016 Tizen TVs are not currently supported. Sorry.
cmcg 876 Posted January 3, 2016 Author Posted January 3, 2016 2.0.4aAdded Shuffle option to play lists.Removed box-shadow effect from images that use cover-art.Better menu open/close animation response."Show disk art" now on by default. ('casue it's so cool!)Notification box updated.Music player icons updated. 5
FrostByte 5453 Posted January 3, 2016 Posted January 3, 2016 2.0.4a "Show disk art" now on by default. ('casue it's so cool!) LOL
deadnex 6 Posted January 3, 2016 Posted January 3, 2016 (edited) Tizen TVs are not currently supported. Sorry. Correction to my previous post: Added my server ip to server.js and repacked zip file seems to have fixed the problem. Now the server selection page was displayed correctly on my Tizen TV (still had to enter ip/server address though). I'm not sure if modifying server.js or repacking the zip file was the cure, but either way the app works perfectly and is very responsive. In other words; I can confirm that Emby is working on my UE65JS8505 Tizen TV. Edited January 3, 2016 by deadnex 4
fc7 123 Posted January 3, 2016 Posted January 3, 2016 (edited) The app looks really awesome in 1080p. There is no way I'm coming back to the sd version!! Thanks @@cmcg Edit: running on UE55H6500 Sent from my iPhone using Tapatalk Edited January 3, 2016 by fc7 2
CBers 7554 Posted January 4, 2016 Posted January 4, 2016 2.0.4a Added Shuffle option to play lists. Removed box-shadow effect from images that use cover-art. Better menu open/close animation response. "Show disk art" now on by default. ('casue it's so cool!) Notification box updated. Music player icons updated. No spinning disc yet Notification box?
FrostByte 5453 Posted January 4, 2016 Posted January 4, 2016 Is it supposed to spin? I don't see a spinning disc either, it does slowly rise up though which is kind of cool
cmcg 876 Posted January 4, 2016 Author Posted January 4, 2016 Is it supposed to spin? I don't see a spinning disc either, it does slowly rise up though which is kind of cool No that was just a sugestion, it just pops up.
FrostByte 5453 Posted January 4, 2016 Posted January 4, 2016 Oh, to me that would be too distracting if it just kept spinning. I like the way it is now
cmcg 876 Posted January 4, 2016 Author Posted January 4, 2016 I think the idea was that it rotates a little as it pops up. Not that it kept spinning forever. That would be awful! 1
CBers 7554 Posted January 4, 2016 Posted January 4, 2016 Is it supposed to spin? I don't see a spinning disc either, it does slowly rise up though which is kind of cool Yes, just a suggestion, by @@shorty1483 I believe. Would be cool if it spun a couple of times though I think Kodi does it in some skins, or is it in MBC. 2
sh0rty 727 Posted January 4, 2016 Posted January 4, 2016 (edited) Yes, just a suggestion, by @@shorty1483 I believe. Would be cool if it spun a couple of times though I think Kodi does it in some skins, or is it in MBC. I thought about Kodi too I like the style in the Titan Skin. And yes @@cmcg I was talking about ugly neverending spinning after popping out like in Kodi cause it looks pretty nice there (for me personally) Edited January 4, 2016 by shorty1483
sh0rty 727 Posted January 4, 2016 Posted January 4, 2016 (edited) And after installing 2.0.4a I want to say again, that this freakin' app looks more and more hilarious from release to release. Absolutely no need to raspberrying around in my living room thanks to @@cmcg and @@chessdragon136 Edited January 4, 2016 by shorty1483 1
TheKamakaZi 15 Posted January 4, 2016 Posted January 4, 2016 (edited) @@cmcg, I have been playing around with 2.0.4a, and love the detail it brings. You're doing an excellent job here. I've also been thinking about the lag issue. Would it be possible to delay the background loading until after the other elements have been loaded, either by event or timer? The WMC app had similar issues when accessed via an XBox 360, and delaying the background loading made a major improvement to the fluidity of the UI. EDIT: As a test to see its effect, could we try disabling backgrounds altogether? Maybe have the splash screen as the background continuously. Edited January 4, 2016 by TheKamakaZi
cmcg 876 Posted January 4, 2016 Author Posted January 4, 2016 @@cmcg, I have been playing around with 2.0.4a, and love the detail it brings. You're doing an excellent job here. I've also been thinking about the lag issue. Would it be possible to delay the background loading until after the other elements have been loaded, either by event or timer? The WMC app had similar issues when accessed via an XBox 360, and delaying the background loading made a major improvement to the fluidity of the UI. EDIT: As a test to see its effect, could we try disabling backgrounds altogether? Maybe have the splash screen as the background continuously. That's a good idea. I'll try it. Thanks.
fc7 123 Posted January 4, 2016 Posted January 4, 2016 (edited) @cmcg: is it possible that the subtitles fix for the problem of the missing last character (included in 1.0.2) is not included in this app? I'm having the same problem again in 2.0.4a. Sent from my iPad using Tapatalk Edited January 4, 2016 by fc7
cmcg 876 Posted January 5, 2016 Author Posted January 5, 2016 I thought about Kodi too I like the style in the Titan Skin. And yes @@cmcg I was talking about ugly neverending spinning after popping out like in Kodi cause it looks pretty nice there (for me personally) Well for a start, the disk is popping out of the spine there. That's just wrong! 3
CBers 7554 Posted January 5, 2016 Posted January 5, 2016 Ahh...makes sense now However, for some reason I can't find that one in the dashboard. It's not listed as an option you can change under episodes in dashboard so I changed mine in the xml What option did you change?
FrostByte 5453 Posted January 5, 2016 Posted January 5, 2016 In the system.xml file where the MetadataOptions start there is an ItemType of "Episode" that I changed the MinWidth of Backdrops to 1920. That one isn't in the dashboard as an option to change. Actually, I went ahead and changed everything that said 1280 to 1920 in that file. Should look like this <MetadataOptions> <ItemType>Episode</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>3</Limit> <MinWidth>1920</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers> <string>Emby Xml</string> </DisabledMetadataSavers> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers /> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> 1
