Larienn 0 Posted December 29, 2015 Posted December 29, 2015 I'm having issues with the guide showing the first 100 entries and not allowing me to go to the next set of listings, nor can I change the limit on the number of channels listed. The issue does not seem to affect the channel tab. I've had this issue for a while using the Android app but was working fine on the server pc using localhost ip. Within the last few changes I started having the issue when using the web interface on external devices when connecting via the app.emby.media site but when I would vpn and type in the local ip, it would work and localhost access on the server pc still worked. With either this latest version or the one before, I've lost it for any means of connecting even on the server. Setup is Windows 8.1, AMD FX-8320E, a Ceton InfiniTV 6, ServerWMC 1.0.0.60 build 1225. Thank you for your time server-63586998859.txt server-63586944000.txt
Luke 42241 Posted December 30, 2015 Posted December 30, 2015 http://emby.media/community/index.php?/topic/29200-using-web-access-under-guide-loads-1st-100-channels-but-not-any-more/
