Guest Posted December 28, 2015 Posted December 28, 2015 Hi there, first big thanks for developing this great program and the apps/tools! I just switched from Plex to Emby due to the unuseable Plex app for Samsung TVs (random crashes, stuttering and/or slow playback etc.) Browsing and playback of music and movies works flawlessly in Emby, but I have problems viewing photos via the inbuild DLNA-server or via the app for the Samsung D-series TVs. Using normal DLNA via "Source" I can see the thumbnails, but when I try to open a picture it says "unsupported file format". In the app it's quite the same, but the error message there is "undefined render error". This happens for all types of images, no matter what format and file-extension they have. Using "MiniDLNA" I can access the images, also when I copy them on an USB-key and plug it directly in the TV. The device identifies itself as "Samsung UE40D5700" and Emby seems to use the DLNA-profile "Samsung TV". What can I do to troubleshoot the problem? TIA Chris
Guest Posted December 28, 2015 Posted December 28, 2015 (edited) I think I found something strange in the server logs: 2015-12-27 23:22:25.9659 Info HttpServer: HTTP Response 500 to 192.168.1.116. Time: 1606ms (slow). http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 2015-12-27 23:22:26.0345 Info HttpServer: HTTP Response 500 to 192.168.1.116. Time: 76ms. http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 2015-12-27 23:22:26.1559 Info HttpServer: HTTP Response 500 to 192.168.1.116. Time: 130ms. http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 2015-12-27 23:22:26.4287 Info HttpServer: HTTP Response 206 to 192.168.1.116. Time: 278ms. http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 2015-12-27 23:22:26.8478 Info HttpServer: HTTP Response 206 to 192.168.1.116. Time: 404ms. http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 2015-12-27 23:22:27.3415 Info HttpServer: HTTP Response 206 to 192.168.1.116. Time: 4ms. http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 2015-12-27 23:22:27.3425 Info HttpServer: HTTP Response 500 to 192.168.1.116. Time: 474ms. http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 2015-12-27 23:22:27.3602 Info HttpServer: HTTP Response 500 to 192.168.1.116. Time: 15ms. http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 2015-12-27 23:22:28.0302 Info HttpServer: HTTP Response 206 to 192.168.1.116. Time: 676ms. http://192.168.1.10:8096/emby/Items/0231ce23568160f427b4494a0c98183a/Images/Primary/0?maxwidth=1920&maxheight=1080&Quality=90 Multiple responses for the same request with 500 and 206 status code?! Also, the image filename is transmitted without extension. AFAIK the Samsung needs proper filename extensions to detect the correct file format, doesn't it? At least MiniDLNA seems to keep the extensions. Here's an excerpt of the log at level "debug": [2015/12/28 20:59:24] clients.c:271: debug: Client found in cache. [Samsung Series [CDEF]/entry 1] [2015/12/28 20:59:24] upnphttp.c:880: debug: HTTP REQUEST: HEAD /MediaItems/26561.jpg HTTP/1.0 getcontentFeatures.dlna.org: 1 Host: 192.168.1.10:8200 [2015/12/28 20:59:24] upnphttp.c:1874: info: Serving DetailID: 26561 [/srv/samba/daten3/Bilder/2015/2015-01-27 Jamaika Urlaub/DSC_6931.JPG] [2015/12/28 20:59:24] clients.c:271: debug: Client found in cache. [Samsung Series [CDEF]/entry 1] [2015/12/28 20:59:24] upnphttp.c:880: debug: HTTP REQUEST: GET /MediaItems/26561.jpg HTTP/1.0 getcontentFeatures.dlna.org: 1 transferMode.dlna.org: Interactive Host: 192.168.1.10:8200 [2015/12/28 20:59:24] upnphttp.c:1874: info: Serving DetailID: 26561 [/srv/samba/daten3/Bilder/2015/2015-01-27 Jamaika Urlaub/DSC_6931.JPG] Edited December 28, 2015 by ChrisTG
Guest Posted February 17, 2016 Posted February 17, 2016 The photo-issue is still not fixed in 3.0.5870 for me. Anything I can do to assist in finding/fixing the problem? TIA!
Luke 42239 Posted February 17, 2016 Posted February 17, 2016 I'm not really sure. I have a samgung tv for dlna testing, and it works perfectly fine there.
Flymy 3 Posted February 18, 2016 Posted February 18, 2016 The photo-issue is still not fixed in 3.0.5870 for me. Anything I can do to assist in finding/fixing the problem? TIA! Can upload a photo which does not work? I'll try it with my Samsung TV!
Guest Posted February 18, 2016 Posted February 18, 2016 Hi Flymy, thank for your offer, but I don't think it's the files, because it doesn't work with *any* photo-file and the error message is always the same. The same files work without any problems with minidlna. They also work with Samsung's "Allshare" software. So I think it's something in Emby's DLNA implementation that my TV doesn't like.
Flymy 3 Posted February 18, 2016 Posted February 18, 2016 Hi Flymy, thank for your offer, but I don't think it's the files, because it doesn't work with *any* photo-file and the error message is always the same. The same files work without any problems with minidlna. They also work with Samsung's "Allshare" software. So I think it's something in Emby's DLNA implementation that my TV doesn't like. Nachdem ich glaube, dass du auch deutsch sprichst, ist es so vermutlich leichter Habe dieses Bild getestet: siehe Anhang. Einfach eines von google! Habe es ausgewählt weil es eine relativ große Auflösung hat. Zuerst wurde mir am TV auch nichts angezeigt. Nachdem aber die Bibliothek idiziert wurde, ist es problemlos gegangen! LG Flymy
Flymy 3 Posted February 18, 2016 Posted February 18, 2016 (edited) FAIL.. wenn du das runter lädst ist es wieder nur klein... hier nochmal das original in voller größe und auflösunghttps://upload.wikimedia.org/wikipedia/commons/e/e8/Hesselbach_Landschaft_suedlich_Ortszentrum_01.JPG Edited February 18, 2016 by Flymy
Guest Posted February 18, 2016 Posted February 18, 2016 Nachdem ich glaube, dass du auch deutsch sprichst, ist es so vermutlich leichter Habe dieses Bild getestet: siehe Anhang. Einfach eines von google! Habe es ausgewählt weil es eine relativ große Auflösung hat. Zuerst wurde mir am TV auch nichts angezeigt. Nachdem aber die Bibliothek idiziert wurde, ist es problemlos gegangen! LG Flymy Hallo Flymy, du liegst richtig mit deiner Vermutung Ich habe das Bild heruntergeladen und in einen separaten Ordner im Share gelegt. Leider das Gleiche: Es wird in der Vorschau angezeigt als Thumbnail, beim Versuch es zu Öffnen kommt "undefined / render error". Auch die Dateirechte und Groß/Kleinschreibung von ".JPG" ändert nichts. Vielleicht ist es auch ein Firmware-Bug im TV, nur verstehe ich dann nicht, wieso minidlna funktioniert... Langsam bin ich ratlos.
Guest Posted February 18, 2016 Posted February 18, 2016 Lade mal dein Profil hier hoch! ??? Was für ein Profil?
Flymy 3 Posted February 19, 2016 Posted February 19, 2016 ??? Was für ein Profil? C:\Users\Name\AppData\Roaming\Emby-Server\config\dlna\user\Profil.xml
Guest Posted February 20, 2016 Posted February 20, 2016 C:\Users\Name\AppData\Roaming\Emby-Server\config\dlna\user\Profil.xml Aha, vermute mal so eine Datei gibt's dann auch (irgendwo) unter Linux. Werd mal schauen, ob ich sie finde.
