EMBY does not start after an update
Hi all,
I am using emby on Centos 7 via the emby repository.
I have amby running all the time.
Therefore, I would expect that emby would be restarted after a yum update.
However, it is not restarted.
Manualy restarting emby is no problem.
Is there a way to make sure that it restarts after update?
I am using systemd.
Thanks for the feedback. I will look into it but no service should be automatically started after installation/upgrade. This is how other services work aswell.
Anyway I will look into the possibily of auto starting the service after and update if it was previously running.
Sent from my iPhone using Tapatalk
