kempe 0 Posted January 6, 2016 Author Posted January 6, 2016 (edited) I don't think it is a platform specific problem but, rather version-specific for the server. I had some episodes do this and no amount of refreshing would fix it. I just refreshed them again now with the dev server and they were fixed. Ok, i will try to install latest dev and see if that are fixing things. btw dev==beta? Edit: I saw that dev !=beta Edited January 6, 2016 by kempe
kempe 0 Posted January 6, 2016 Author Posted January 6, 2016 (edited) I tried beta before i tried dev and can confirm that everything worked as expected with emby-beta so there is a bug or something in the stable version. And it also fixed naming issues that i had on shows that wasn't miss-match for example a couple of episodes in Last Week Tonight with John Oliver was named just by file name but after a rescan they have the correct naming and every other show I've checked so far too. Nice Edited January 6, 2016 by kempe
Luke 42288 Posted January 6, 2016 Posted January 6, 2016 There should be no difference with dev and beta, but there might be some differences with beta and stable.
ebr 16354 Posted January 6, 2016 Posted January 6, 2016 There should be no difference with dev and beta, but there might be some differences with beta and stable. Yes, it appears to be able to re-identify them properly with dev (and, presumably beta) but not the current stable release.
Luke 42288 Posted January 6, 2016 Posted January 6, 2016 The only difference is the new support for internet metadata for daily episodes, although it's possible that during the implementation of that some other bug was fixed. I will promote that feature to stable as it's been in beta for a couple weeks and there's been no issues reported against it. 1
