jscoys 147 Posted December 27, 2015 Posted December 27, 2015 Hi, it's for sure a problem for people who like to switch beetween several languages. As you can see on this video : https://youtu.be/DBQLCosD93E If we cast and go into control area, we can't switch to another languages or subtiles and we're forced to use the defaults ones. Could someone confirm the same comportement?
Luke 42243 Posted December 27, 2015 Posted December 27, 2015 This has to do with the chromecast receiver. You CAN switch subtitles if the Chromecast app can change the subtitles without stopping and restarting the video. If it needs to stop and restart the video, then this is not implemented yet in the chromecast receiver, and that's also why changing audio tracks doesn't work yet. I'll try to add support for that soon.
jscoys 147 Posted December 27, 2015 Author Posted December 27, 2015 Ok thx Luke, features very important 4 me. Sent from my iPhone using Tapatalk
Luke 42243 Posted January 6, 2016 Posted January 6, 2016 @@jscoys, changing audio tracks has been added to our beta chromecast receiver using the dev server and the web client, in case you'd like to try it out: http://emby.media/community/index.php?/topic/29402-305845-chromecast/
jscoys 147 Posted January 8, 2016 Author Posted January 8, 2016 @@Luke : Thx very much it works great now! Just one or two things to debug : If I have only one subtitle in a movie, this one is selected by default and I haven't any possibility to remove it from Ios App. (It's selected and if I click on it it remains selected...). Second bug is If I have a theme music for a movie, it starts to play on my Ios Device. If I select my ChromeCast and then play the movie, the theme music continues to play on my Ios Device and Meanwhile the movie is played on ChromeCast. What is very anoying is if I click on stop button on the bottom bar it stops the theme music on my IOS Device AND the movie playing on the ChromeCast, like the same button is used for both playback??? If you resolve these two bugs, it will be the perfect ChromeCast streaming software!
Luke 42243 Posted January 8, 2016 Posted January 8, 2016 You're saying there's no Off option in the subtitle menu, or there is but it's not working?
jscoys 147 Posted January 9, 2016 Author Posted January 9, 2016 No. As you can see on this picture if i click on cc we can see thaï the only one subtitle available in the movie is activated when launching it and i don't have any option to deactivate it.
jscoys 147 Posted January 26, 2016 Author Posted January 26, 2016 As you can see on this picture of my iPhone playing directly a video, if I would like to select subtitles, I have an option "off". That's this option that is expected to be found on Chrome cast sub selection. Sent from my iPhone using Tapatalk
Luke 42243 Posted January 26, 2016 Posted January 26, 2016 Thanks, I see the issue. It's being resolved for the next update.
