mwkurt 5 Posted December 27, 2015 Posted December 27, 2015 (edited) Hello, I have installed Emby Server on a Windows machine. This machine also has Kodi installed and I am trying to install Emby for Kodi as well on the same machine. I am not getting my TV and movie libraries to show on Kodi mainscreen. Could someone point me to the correct settings needed? Thanks! Mark kodi.log Edited December 27, 2015 by mwkurt
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 Are you trying to use your emby connect user (forum username)? Because we do not support Emby connect at this time. Could you post your log from after you try to enter the password? If there's no password, it should not ask for it, unless the user is hidden on your server. Let me know.
mwkurt 5 Posted December 27, 2015 Author Posted December 27, 2015 Hello Angelblue05, No...was not trying my username password. I am not sure what to do to get Emby to work. May have the password thing working. IDK. Have attached log. Thanks, Mark
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 Can you enable the add-on debug (add-on settings > advanced > debug set to Info) and post another log. No information was captured in your last log. In your emby dashboard > users : These are the user info you want to put in when you first set up Emby for Kodi. You can select the user and check the password tab to make sure there's no password set up in your emby server.
mwkurt 5 Posted December 27, 2015 Author Posted December 27, 2015 Thankyou Angelblu05, Entered the user name and am connected now. Thank you again!!!!! 1
