emko 6 Posted December 25, 2015 Posted December 25, 2015 Going to Emby,Tv Shows,Next Episode same thing with Anime it lists the next episodes but it wont play any of them or show the info when i press "i" or the info button on my remote. " Playback failed One or more items failed to play..." Was working on .62 kodi.log
Angelblue05 4132 Posted December 25, 2015 Posted December 25, 2015 Ok I'll look into it later today. Thanks for reporting! Sent from my iPhone using Tapatalk
Angelblue05 4132 Posted December 26, 2015 Posted December 26, 2015 Can you give 1.1.66 a try for next episode? They should be playing now. The metadata should display at list level. However, no matter what I try (even with stable version), the info dialog doesn't display correctly. I am still looking into it.
emko 6 Posted December 26, 2015 Author Posted December 26, 2015 Can you give 1.1.66 a try for next episode? They should be playing now. The metadata should display at list level. However, no matter what I try (even with stable version), the info dialog doesn't display correctly. I am still looking into it. yea i just test .62 was doing the same it shows the info but not all of it or cast etc at least the playback is working thanks 1
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 Thanks for confirming playback works. I'm still looking into the info dialog situation. I will let you know if I figure something out. Even on stable, most metadata is also missing from the info dialog.
