emko 6 Posted December 27, 2015 Author Posted December 27, 2015 Still no fanart showing? fanart shows in movies view and tv shows view but on the main skin page spotlight it does not also browsing around in the movies/tv shows the textures13.db increase in size and the fanart will then show up on the main menu spotlight this all worked on .62 release 1
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 I don't know what could explain the outcome you are having. I'll get back to you on this. According to your last log, the script skin helper looked to be fine (as in, no more crash)
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 fanart shows in movies view and tv shows view but on the main skin page spotlight it does not also browsing around in the movies/tv shows the textures13.db increase in size and the fanart will then show up on the main menu spotlight this all worked on .62 release I should have been more precise, the add-on only caches the fanart and poster. Kodi still caches everything else (all other type of artwork displayed, including people), so it's normal to see textures13.db increase while browsing.
emko 6 Posted December 27, 2015 Author Posted December 27, 2015 (edited) debug log for post after this kodi - Copy.zip Edited December 27, 2015 by emko
emko 6 Posted December 27, 2015 Author Posted December 27, 2015 I should have been more precise, the add-on only caches the fanart and poster. Kodi still caches everything else (all other type of artwork displayed, including people), so it's normal to see textures13.db increase while browsing. i don't really understand but once i go to movies and highlight a movie the texture size increases and then this one movie fanart will show in the spotlight, in .62 fanart loaded fine in the spotlight. "auto add images to the kodi texture cache" seems not to do anything the size of the textures13.db never increases during the db reset i turned on kodi debugging and ran the db reset for a bit so the logs wont be so big hope it helps i will go back to .62 see how that worked.
emko 6 Posted December 27, 2015 Author Posted December 27, 2015 (edited) ok back on .62 the textures13.db is increasing very fast that's the only thing i can think is wrong .66 option "auto add images to the kodi texture cache" is not working i see in the .62 logs 18:21:00 T:28176 NOTICE: EMBY TextureCache -> logMsg : Adding Art Link for kodiId: and in .66 this never happens Edited December 27, 2015 by emko
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 (edited) Yeah, I see it too now. I've just removed all thumbnails and textures13.db Thanks for looking and testing emko. Will let you know once I have something for you to try out. Edited December 27, 2015 by Angelblue05
emko 6 Posted December 27, 2015 Author Posted December 27, 2015 Yeah, I see it too now. I've just removed all thumbnails and textures13.db Thanks for looking and testing emko. Will let you know once I have something for you to try out. No problem thank you for working so hard on this
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 Good news, found the cache issue. I'm still looking into the extra fanart lag. 1
emko 6 Posted December 27, 2015 Author Posted December 27, 2015 (edited) Good news, found the cache issue. I'm still looking into the extra fanart lag. nice let me know if you need me to test anything thanks i tested it works good now, i don't know what the extra fanart lag issue is maybe someone else has that problem Edited December 27, 2015 by emko 1
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 (edited) Hah, you are quick The lag When you move your cursor around in the movie library, the fanart doesn't change. I suspect since the path is the same for all movies, it's not treating it as a new item to display. I might have to change the movie paths. This is only an issue when extra fanart is enabled. Otherwise it works fine in Kodi. I don't want to force marcelveldt to adjust his script. Edit: Yeah, just as I thought, it's because the path doesn't change. Hm... Edited December 27, 2015 by Angelblue05
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 The fix for artwork cache is in 1.1.67 Unchanging fanart in the movie library is still being worked on. However, there's already another thread for it, so I marked this thread as completed.
badaas 139 Posted December 27, 2015 Posted December 27, 2015 I was going to saay its multi fanart.. xmas beer sidetracked me!!! 1
Angelblue05 4132 Posted December 27, 2015 Posted December 27, 2015 Indeed badass. I've messaged marcelveldt to see if it would be an easy fix for his script. In fixing other bugs in the addon, I didn't realize multi fanart would break if the path was identical for all movies. Only the filename differs, so the script no longer picks up that the cursor is not on the same item if you move it around (the exception being boxsets). Sent from my iPhone using Tapatalk 1
