dark.neo29 1 Posted December 24, 2015 Posted December 24, 2015 Running Android 5.1.1 and Kodi 15.2 with Emby plugin. Audio goes in and out every 3 seconds. Has this been seen before?
Angelblue05 4132 Posted December 24, 2015 Posted December 24, 2015 What are your settings in Kodi settings > System > Audio output? (make sure the settings level is set to advanced or higher to see all the settings)
dark.neo29 1 Posted December 24, 2015 Author Posted December 24, 2015 What are your settings in Kodi settings > System > Audio output? (make sure the settings level is set to advanced or higher to see all the settings) I have Pass through on and DTS enabled.
Solution dark.neo29 1 Posted December 24, 2015 Author Solution Posted December 24, 2015 I have Pass through on and DTS enabled. Well i am an idiot. Its only 1 file and this happen to be the only file I was trying on the new Android 5.1.1. Tried 13 other movie files and TV shows and no issues. 1
