Mentalblaze 9 Posted December 22, 2015 Posted December 22, 2015 I use Emby on OpenMediaVault and I have four locations for tv-shows. All seems to work except the share on OMV itself. I get multiple errors of this kind: 2015-12-22 14:47:59.0782 Error - FileSystem: Error determining LastAccessTimeUtc for /ior/Media/TVserier1/Fastlane/Fastlane - s01e05 - Ryde or Die.avi *** Error Report *** Version: 3.0.5781.4 Command line: /opt/emby/MediaBrowser.Server.Mono.exe -programdata /media/a6eceb29-64d8-48b4-8703-1f79c9c59f08/emby -restartpath /usr/sbin/emby.sh Operating system: Unix 3.2.0.4 Processor count: 2 64-Bit OS: True 64-Bit Process: True Program data path: /media/a6eceb29-64d8-48b4-8703-1f79c9c59f08/emby Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Nov 12 09:52:44 UTC 2015) Application Path: /opt/emby/MediaBrowser.Server.Mono.exe Not a valid Win32 FileTime. Parameter name: fileTime System.ArgumentOutOfRangeException at System.DateTime.FromFileTimeUtc (Int64 fileTime) <0x7fcbfab5db10 + 0x0009a> in <filename unknown>:0 at System.DateTime.FromFileTime (Int64 fileTime) <0x7fcbfab5dad0 + 0x0001b> in <filename unknown>:0 at System.IO.FileSystemInfo.get_LastWriteTime () <0x7fcbfad5ac20 + 0x00026> in <filename unknown>:0 at System.IO.FileSystemInfo.get_LastWriteTimeUtc () <0x7fcbfad5ad10 + 0x00027> in <filename unknown>:0 at (wrapper remoting-invoke-with-check) System.IO.FileSystemInfo:get_LastWriteTimeUtc () at CommonIO.ManagedFileSystem.GetLastWriteTimeUtc (System.IO.FileSystemInfo info) <0x41518910 + 0x0003e> in <filename unknown>:0 But there are other shows that won't show up at all. Not in the log nor in the Library.
Luke 42243 Posted December 22, 2015 Posted December 22, 2015 Hi, welcome. Sorry to hear about your troubles. Please provide the complete log file, thanks.
Mentalblaze 9 Posted December 25, 2015 Author Posted December 25, 2015 First I found a workaround, I added the folder in a new library, selecting category as "unset". That way averything is shown without then need for scanning. But I also removed and readded the folder in the original library as well and now, a couple of days later, the shows have shown up.
Luke 42243 Posted December 25, 2015 Posted December 25, 2015 Well done. If changing to unset fixed it then it likely means there are some unsupported naming conventions being used.
