gbone8106 25 Posted December 22, 2015 Posted December 22, 2015 I am attemping to play star wars which has a DTS-MA 6.1 and a DTS-ES 6.1 track, I have not been able to get this to play, in the log is says channel compatibility is false - 7, it seems to be transcoding, I though that was fixed? any one else have this issue? btw H series tv , v1.0.0
FrostByte 5453 Posted December 22, 2015 Posted December 22, 2015 I'll check see if it still works on my tv. I think the code may have only been put in for my tv (F series) as a test and never made it to the other models. I can check GitHub, but it should be a easy fix for cmcg
FrostByte 5453 Posted December 22, 2015 Posted December 22, 2015 @@cmcg can you change lines 381, 505, and 568 to 7 channels? Thanks 378 case "dca": 379 this.audiocodec = true; 380 this.audiocontainer = ["asf","avi","mkv","mp4","3gpp","mpg","mpeg","ts","m4v","m2ts","mov","vro","tp","trp","flv","vob","svi","mts","divx"]; 381 this.audiochannels = 6; 382 break; 1
gbone8106 25 Posted December 22, 2015 Author Posted December 22, 2015 here is a sample http://1drv.ms/1m66BIY
3psus 3 Posted December 22, 2015 Posted December 22, 2015 Although I am not using Samsung Smart TV, I am experiencing a similar problem on iOS and Chrome browser. It is being discussed here: http://emby.media/community/index.php?/topic/28865-bug-truehd-playback-results-in-playback-error/&do=findComment&comment=278419
