popy 73 Posted December 31, 2016 Posted December 31, 2016 Sort order "default" is the visible sort order you can see in TVServer. Sort order "channel id" uses TVServers internal number that you see in the tuning details, if you edit a channel. Sort order "name" uses, you can guess it, the channel name. In every case MPExtended never returns any self assigned channel numbers. This is just missing in MPExtended! Because of this, the plugin creates its own channel numbers (depending on the sort option) from 1 to unlimited with the option "enable channel index". I think my plugin is doing all right here - it is an Emby problem. I could create a plugin version with further logging, that shows you how the plugin delivers your channels to Emby? Any progress on this My sort order does'nt match TV server, no matter which sort order setting i have set. Happy new year!
pünktchen 1410 Posted December 31, 2016 Posted December 31, 2016 Any progress on this [emoji14] My sort order does'nt match TV server, no matter which sort order setting i have set. Happy new year! Happy new year! What progress do you expect? Your Emby guide matches the sort order of your TVServer. Nothing more to do here from the plugin side. The plugin delivers the channels only one time - there's no seperation between guide and channels.
popy 73 Posted December 31, 2016 Posted December 31, 2016 Happy new year! What progress do you expect? Your Emby guide matches the sort order of your TVServer. Nothing more to do here from the plugin side. The plugin delivers the channels only one time - there's no seperation between guide and channels. MP TV Server with dedicated "Emby" group: Channel sort settings in emby: And the result in emby: It makes no difference which sort order setting i am choosing, the result is always wrong. Also with or without the "id" checkbox. What i am doing wrong? Happy new year!
pünktchen 1410 Posted December 31, 2016 Posted December 31, 2016 Are you joking? Three posts earlier you've said it was okay in the guide after unchecking "Platziere Favoriten am Anfang" and now you've enabled this option again!?
popy 73 Posted December 31, 2016 Posted December 31, 2016 Are you joking? Three posts earlier you've said it was okay in the guide after unchecking "Platziere Favoriten am Anfang" and now you've enabled this option again!?Sorry, my fault. I have accidentally activated the setting. Now channels on guide are correctly ordered. But under 'channels' they are wrong. So it's an emby issue? Because favorite channels are shown first on the channel page. @Luke: any chance to get a fix? pOpY Gesendet von meinem LG-H815 mit Tapatalk
pünktchen 1410 Posted January 9, 2017 Posted January 9, 2017 @@popy channel view sorting should be resolved with next server release: https://emby.media/community/index.php?/topic/43457-Sort-Channels 1
popy 73 Posted January 9, 2017 Posted January 9, 2017 @@popy channel view sorting should be resolved with next server release: https://emby.media/community/index.php?/topic/43457-Sort-ChannelsThx for the info!pOpY Gesendet von meinem LG-H815 mit Tapatalk
popy 73 Posted February 3, 2017 Posted February 3, 2017 thx, tested with "Emby Server 3.1.4" and issue is gone. pOpY
