fc7 123 Posted December 26, 2015 Author Posted December 26, 2015 what about configuring the proxy to ignore it? To ignore what exactly?
fc7 123 Posted December 26, 2015 Author Posted December 26, 2015 the absence of Authorization I was just looking into doing that for specific requests (the ones that comes with a specific ORIGIN header). Doing it for all of them, means disabling proxy authentication and I don't really want to do that. Also I want to understand what's is actually going on and the implications of changing the proxy configuration, if any. If in the end the only option is to disable proxy authentication, I prefer to rollback Emby to the previous stable version and stay there until any better option arise.
fc7 123 Posted December 26, 2015 Author Posted December 26, 2015 Ok. I just rolledback to the previous version 3.0.5781.5 and everything works fine with the same proxy setup and using Firefox 43. Thank God I'm using a VM and it was as simple as switching the virtual hdd. I have now two virtual hdds one with Emby 3.0.5781.8 and another one with 3.0.5781.5 to continue with the troubleshooting. @Luke: if you come up with any idea (knowing all the code changes made between versions in the webclient) on what can I test, I will go back to 3.0.5781.8 and test it. No problem. Just let me know.
fc7 123 Posted December 26, 2015 Author Posted December 26, 2015 (edited) @Luke: the works "cross-domain", "cors" keep coming up. Forgive me if what I'm about to say is totally non-sense but is it possible that for some reason the browser thinks that he needs to a cross-domain request and hence why it's dropping the Authorization header and adding the Origin header for the requests that fails? I compare the requests done using the previous stable Emby version and the browser is not using the Origin header at all when its requesting "users/public" and "Branding/Configuration". I just wish I have more developing skills and knowledge to figure this out. For example: Request with credentialsBy default, for non same origin request, browsers will not send credentials (such as HTTP Cookies, HTTP Authentication and client-side SSL certificates). A specific attribute has to be set on the XMLHttpRequest object when it is invoked. Edited December 26, 2015 by fc7
fc7 123 Posted December 26, 2015 Author Posted December 26, 2015 (edited) More information. Firefox 38 is the last version that works with the latest stable Emby release (.8) with this reverse-proxy setup. Anything afterwards will fail. Edited December 26, 2015 by fc7
fc7 123 Posted December 27, 2015 Author Posted December 27, 2015 (edited) try the dev branch It works!!! What was the problem? Any chance that the fix will go into stable soon? Edited December 27, 2015 by fc7
Luke 42243 Posted December 27, 2015 Posted December 27, 2015 Did your test include this commit? https://github.com/MediaBrowser/Emby/commit/e8bc3ce5987e46d6bc8370fac6f1e53ff6cfadb4 And if so, what version of mono? and if not, can you grab that and retry? thanks.
fc7 123 Posted December 27, 2015 Author Posted December 27, 2015 (edited) Did your test include this commit? https://github.com/MediaBrowser/Emby/commit/e8bc3ce5987e46d6bc8370fac6f1e53ff6cfadb4 And if so, what version of mono? and if not, can you grab that and retry? thanks. Yes. I waited for OBS to build the dev package for that commit. Mono version 4.0.3. Edited December 27, 2015 by fc7
Solution fc7 123 Posted December 28, 2015 Author Solution Posted December 28, 2015 Solved in Emby stable 3.0.5782.0.
semafoor 0 Posted February 5, 2016 Posted February 5, 2016 (edited) Edit: moved by new (related) problem to a new thread instead: http://emby.media/community/index.php?/topic/30946-error-401-on-streammkv-in-chrome-emby-305821/ Edited February 5, 2016 by semafoor
gstuartj 40 Posted February 5, 2016 Posted February 5, 2016 (edited) @@fc7 I'm curious, what benefits are there to using HTTP basic auth? Hiding the login form/public parts of Emby from random visitors? With your setup do users still have to login a second time using the login web form, or are you passing those basic auth params to Emby somehow? Does basic auth work with all clients, e.g. Roku? I'm happy with my setup, but if HTTP basic auth can work fairly seamlessly I'm interested. Edited February 5, 2016 by gstuartj
fc7 123 Posted February 7, 2016 Author Posted February 7, 2016 @@fc7 I'm curious, what benefits are there to using HTTP basic auth? Hiding the login form/public parts of Emby from random visitors? With your setup do users still have to login a second time using the login web form, or are you passing those basic auth params to Emby somehow? Does basic auth work with all clients, e.g. Roku? I'm happy with my setup, but if HTTP basic auth can work fairly seamlessly I'm interested. In my case the benefit is that I add an extra security layer since unauthorized visitors don't get to Emby at all. If there is any security flaw in mono or Emby that can be exploited this will also reduce the attack surface since someone would need first to get authorized by the proxy and only then they get to Emby. Also this added authentication layer is integrated with Active Directory, which makes user access a lot more easy to control. To give you a broader picture, I have a few public sites published to the Internet. With this setup I can grant different users access to different sites, based on their Active Directory group membership which is pretty handy for me. Yes, the users need to login twice, first against the proxy and then against Emby using the regular Emby login form. Regading Emby client apps, I don't think they will work, but my users only use the webclient.
