irengineer 4 Posted December 9, 2013 Posted December 9, 2013 Is there a setting in MBT to have the home be the collections view? It is possible in Roku and Android (among others maybe) and it would be great if I could do that in MBT. Thanks. Since I'm here, autologin would be a bug plus for WAF too. I know you're working on it. 1
Jooced 6 Posted December 9, 2013 Posted December 9, 2013 Since I'm here, autologin would be a bug plus for WAF too. I know you're working on it. Autologin is in the latest dev build and working well.
irengineer 4 Posted December 9, 2013 Author Posted December 9, 2013 Autologin is in the latest dev build and working well. I can't wait!!
gcw07 347 Posted December 10, 2013 Posted December 10, 2013 Really if this is going to be implemented it should be implemented correctly. And that means giving the option to default to movies, music, tv, or collections.
ebr 16331 Posted December 10, 2013 Posted December 10, 2013 Really if this is going to be implemented it should be implemented correctly. And that means giving the option to default to movies, music, tv, or collections. The simple and flexible (new categories would work too) way to do that would be to just allow you to specify the order in which they all appear.
gcw07 347 Posted December 10, 2013 Posted December 10, 2013 The simple and flexible (new categories would work too) way to do that would be to just allow you to specify the order in which they all appear. Yeah that works too.
