dragon2611 29 Posted December 20, 2015 Posted December 20, 2015 Am I right in thinking the Live TV in the Android/FireTV apps would be streamed via the server? At the moment I have kodi on my fireTV stick, it connects to Emby via the plugin for content off my emby server and then directly to tv headend for live stuff. I know Emby supports liveTV stuff but I've never tried it because the servers remote, presumably if I tried via emby it would be Tv headend > Emby server > Client? This would essentially mean I'd be uploading the stream across the internet just to pull it back again, not sure if that would work very well (Have about 15-20Mbit/s of upload) Also wondering if it's worth swapping my fireTV and fireTV stick around so that I use the more powerful fireTV for emby (I don't bother at the moment as the Sat box (WeTek play) is on the same TV as the fireTV so I just use the kodi emby plugin on the sat box)
ebr 16335 Posted December 20, 2015 Posted December 20, 2015 Are you saying that your Live TV implementation/hardware is not on the same network as your Emby Server?
dragon2611 29 Posted December 20, 2015 Author Posted December 20, 2015 Are you saying that your Live TV implementation/hardware is not on the same network as your Emby Server? Correct, my Emby server is a VM on a co-located server sitting in a datacentre. My Satellite box at home is a Wetek play running OpenElec and Tv headend. (http://wetek.com/product/wetek-play). I have it setup to stream content From emby but I never bothered setting up live TV in emby itself.
thaddeusferber 2 Posted January 18, 2016 Posted January 18, 2016 Hi Dragon, How is your set up working? I am curious about the idea of running an Emby server in a colo.
dragon2611 29 Posted January 19, 2016 Author Posted January 19, 2016 (edited) Fine other than DLNA doesn't work as not on the same LAN, I could probably proxy it via the VPN I have in place, but I haven't bothered as I just use Kodi or the Apps. That said I have ~70-80Mbit/s of downstream bandwidth at home, hopefully increasing later this week (Upgrading my backup line to VDSL and going to attempt to bond them) Edited January 19, 2016 by dragon2611
