copy freely channels after #298 are blocked after reboot
All channels work in wmc. All worked when first set up with server wmc then i rebooted and only the first channels 2 thru 298 show up any number higher than 298 is blocked no mater what is checked off in serverwmc.
i checked many channels and they are marked copy freely but are being blocked in wmc?
why would copy freely channels be blocked?
see the log attached
Total LineUps: 1, Total channels imported: 298
Channels found in database: 533
Ignored Channels> Blocked in WMC: 298, User hidden: 0
Strange Channels> Null space: 0, Out-of-range(ignored): 0
Protected Channels> encrypted: 0 DRM: 0
Edited Channels> Callsigns: 0, Numbers: 0
Channel Groups> Found: 1
GetLineUpsAndChannels> Ignored Channel Groups> Blocked in WMC: 0, Empty groups: 0
ServerWMC.log
config.xml
Edited by crunch
Do they work when using wmc? Removing emby and serverwmc from the picture
krustyreturns
Yeah, according to the log they are blocked in wmc.  See if they are showing up in the guide in wmc, if they aren't, go to wmc's channel settings and enable them again.
Yes All "533" channels found are viewable and record in amc.
. The 298 channels are only blocked some how in server wmc
Ceton tuner shows channels flagged copy freely yet they are being blocked somehow
Edited by crunch
krustyreturns
The aren't getting blocked due to copy protection, this line:
means that 298 channels read in from the wmc database are flagged as Blocked by wmc.  Channels get marked as blocked when they have been disabled in wmc.  If none of these channels are disabled in wmc, then I'm at a loss.  All I can think is that the database is messed up (but that doesn't explain why wmc doesn't show a problem).  Try going into wmc for one of these missing channels and first disable it then re-enable it.  Then start swmc and see if it adds the channel you toggled.
Edit: you could also set "restore defaults" in the channel edit page of wmc and then save.  That might do it too.
Edited by krustyreturns
