JoachimGR 0 Posted December 19, 2015 Posted December 19, 2015 Hi, I'm new at emby. I've installed the Windows-Server and it runs well. But I've a strange Problem. If the source (ISO ripped from DVD) have a aspect ratio DAR 16:9 ffmpeg encode with a optimal Bitrate Stream #0:0: Video: h264 (libx264), yuv420p, 720x576 [sAR 64:45 DAR 16:9], q=-1--1, 7680 kb/s, 25 fps, 90k tbn, 25 Tbc If the source (also ISO ripped from DVD) have a aspect ratio DAR 4:3 ffmpeg encode with a very low Bitrate Stream #0:0: Video: h264 (libx264), yuv420p, 426x318 [sAR 212:213 DAR 4:3], q=-1--1, 100 kb/s, 25 fps, 90k tbn, 25 tbc Does'nt matter what client (Android, Web-Browser, local or over a WAN) I use. I attach two log-files, one with high, the other with low Bitrate. Anyone a solution? Regards Joachim High Bitrate.txt Low Bitrate.txt
Luke 42185 Posted December 19, 2015 Posted December 19, 2015 hi, can you provide the media info as displayed in the web interface? thanks.
JoachimGR 0 Posted December 19, 2015 Author Posted December 19, 2015 Thanks for the very quick Response
Luke 42185 Posted December 19, 2015 Posted December 19, 2015 Ok, so the bitrate detection of the ISO produced a very low number. I will have to adjust that and ignore the low value.
Luke 42185 Posted December 19, 2015 Posted December 19, 2015 as a test, can you take the first vob of the iso VTS_01_1.VOB copy that into your movie library temporarily, just that one file. let me know how that goes. thanks.
JoachimGR 0 Posted December 19, 2015 Author Posted December 19, 2015 That runs well..... Output #0, hls, to 'C:\Transcoding\transcoding-temp\8a464c94c9984628f23a9adb0891f28a.m3u8': Metadata: encoder : Lavf56.18.100 Stream #0:0: Video: h264 (libx264), yuv420p, 720x576 [sAR 16:15 DAR 4:3], q=-1--1, 7680 kb/s, 25 fps, 90k tbn, 25 tbc
