funkysteve 0 Posted December 19, 2015 Posted December 19, 2015 Why can I not add a movie folder from an external hard drive. I keep getting the message Please ensure the path is valid and the Emby Server process has access to that location. Any help would be greatly appreciated. If I can't use Emby with an external hard drive the program is useless.
mjktg99 35 Posted December 19, 2015 Posted December 19, 2015 (edited) Is the external hdd on the same system as emby server? How are you trying to add it? Edited December 19, 2015 by mjktg99
ebr 16307 Posted December 19, 2015 Posted December 19, 2015 It has to actually be attached and available to the system when you add it. After that, you can take it off-line.
funkysteve 0 Posted December 19, 2015 Author Posted December 19, 2015 Hard drive is attached to laptop via usb. tried direct path E:\movies and network path and tried a path substitution. same message every time
mjktg99 35 Posted December 20, 2015 Posted December 20, 2015 Is your laptop the same device the server is running on? If not, you need to share and provide permission to the account that is running the server.
funkysteve 0 Posted December 20, 2015 Author Posted December 20, 2015 (edited) Yes server is installed and running on laptop. hard drive and folder is shared. I can add a folder on my laptop hard drive no problem just get the error when I try to add the external drive to the library Edited December 20, 2015 by funkysteve
mjktg99 35 Posted December 20, 2015 Posted December 20, 2015 How are you running your server? As a service or as an app?
funkysteve 0 Posted December 20, 2015 Author Posted December 20, 2015 Using Emby for WMC and the server app that runs in the background I guess.
funkysteve 0 Posted December 20, 2015 Author Posted December 20, 2015 Ok figured it out. It was a classic PEBKAC error. was trying to add a second movie folder instead of adding it to the existing movie folder. tyvm for your help. problem solved
