Happy2Play 9802 Posted February 4, 2018 Posted February 4, 2018 @@Luke @@wedgekc provided the steps to reproduce this. If user A creates playlist user B cannot see it if they have no playlists. But if you create a playlist in user B also, both users see all playlists.
Abobader 3485 Posted February 4, 2018 Posted February 4, 2018 Good day, I confirm this as well. My best
DarkFeather 3 Posted March 8, 2018 Posted March 8, 2018 (edited) Luke, I want to report another problem. I updated to Version 3.3.1.3 beta to try to install the LDAP plugin. Unfortunately, now playlists are completely broken. I've attached a pic of the symptoms. https://imagebin.ca/v/3uD4ACodVacc Edited March 8, 2018 by DarkFeather
Luke 42213 Posted March 9, 2018 Posted March 9, 2018 Luke, I want to report another problem. I updated to Version 3.3.1.3 beta to try to install the LDAP plugin. Unfortunately, now playlists are completely broken. I've attached a pic of the symptoms. https://imagebin.ca/v/3uD4ACodVacc https://emby.media/community/index.php?/topic/56823-3312-beta-for-windows-playlists-messed-up/
shocker 135 Posted March 25, 2018 Posted March 25, 2018 Hello, @@Luke a new bug has been introduced on 3.3.1.8 regarding the playlists. If you click the playlist library you can see the playlist for all users on server. Thanks
Luke 42213 Posted March 25, 2018 Posted March 25, 2018 I'm not able to reproduce this. @@Happy2Play are you seeing this?
Happy2Play 9802 Posted March 25, 2018 Posted March 25, 2018 I'm not able to reproduce this. @@Happy2Play are you seeing this? Actually a old issue, but yes. Steps to reproduce https://emby.media/community/index.php?/topic/28717-playlists-and-multiple-users/?p=541583 @@shocker merged into here
computerprep 148 Posted July 13, 2018 Posted July 13, 2018 (edited) This bug just reared it's ugly head on my setup. Are there any fixes on the horizon for this? Just posted over here (https://emby.media/community/index.php?/topic/51427-share-playlists-with-other-usersguests) about the problem before finding this thread. Steps to reproduce seem identical. Edited July 13, 2018 by computerprep
guynamedbilly 18 Posted September 19, 2018 Posted September 19, 2018 (edited) This bug just reared it's ugly head on my setup. Are there any fixes on the horizon for this? Just posted over here (https://emby.media/community/index.php?/topic/51427-share-playlists-with-other-usersguests) about the problem before finding this thread. Steps to reproduce seem identical. I am experiencing this too. Any fix in the works? What's even worse is I have a profile set up for my kids and I don't have playlists available on their home I only allow them access to certain kid friendly libraries. If I'm on their profile and I create a playlist, I can then watch the movies on other playlists that they should not be allowed to watch because of the library permissions. I had to create a playlist for their profile so I could then go into profile options and tell it to not display playlists on their home screen. Edited September 19, 2018 by guynamedbilly
computerprep 148 Posted September 19, 2018 Posted September 19, 2018 Without scrolling through this entire thread, I'm not sure if anyone else has posted a temporary fix for this. You are able to give the playlist a tag, then hide that tag from all other users. The way I use this workaround is to add every other username into the blocked tags list for each user. Then when I create a playlist, I immediately add my username into it's tags. I've instructed all my users to do the same if they want to keep their playlists private. 2
YondaimeCB 0 Posted October 16, 2018 Posted October 16, 2018 Also have this issue.. currently on version 3.5.3.0, any fix we can try? thank you! Actually a old issue, but yes. Steps to reproduce https://emby.media/community/index.php?/topic/28717-playlists-and-multiple-users/?p=541583 @@shocker merged into here
YondaimeCB 0 Posted October 16, 2018 Posted October 16, 2018 for some reason if userA creates a playlist, userB can see userA's playlist and can edit/delete, not sure why it's being shared by default?
Luke 42213 Posted October 16, 2018 Posted October 16, 2018 We plan to revamp playlist sharing and management in a future update. Thanks !
crxo 4 Posted May 4, 2020 Posted May 4, 2020 Hey, sorry for bringing up this old thread, but the issue that all users can see / edit / delete the playlists from other users still persists in 4.4.2.0.. Even when you disable the access to playlists for a user, he still can add titles to all other users playlists over the context menu. 2
Luke 42213 Posted May 5, 2020 Posted May 5, 2020 We hope to be able to get to this soon. Thanks for the feedback. 2
Punch 19 Posted May 25, 2020 Posted May 25, 2020 Hey, sorry for bringing up this old thread, but the issue that all users can see / edit / delete the playlists from other users still persists in 4.4.2.0.. Even when you disable the access to playlists for a user, he still can add titles to all other users playlists over the context menu. Oh yes i just came looking for this.. This is causing havoc bewteen users. Can this be moved up to the next release i possible please, it's literally causing problems
