MongooseMan 31 Posted December 18, 2015 Posted December 18, 2015 Just installed latest stable. I always set my home views as follows: 1 - Favourite series 2 - Next Up After setting them in the settings menu, if I close and open the app, the home views shown reset to "Continue watching" and "Favourite Series". Note that, in the settings menu, the items I chose above are still listed, but that's not what shows in reality. No matter what I choose in the settings menu (let's say "ViewA" and "ViewB", it always resets to this combination: "Continue watching" and "ViewA" (where "ViewA" is now shown in the lower section, even it is set as Home View 1.
Solution CBers 7554 Posted December 18, 2015 Solution Posted December 18, 2015 Renamed "Resume All Items" to "Continue Watching".Show "Continue Watching" on the home page moved to a separate user option HV1 is now used for Continue Watching items, if enabled in the settings. In effect, although the names haven't changed, HV1 is now HV2 and HV2 is now HV3. 2
MongooseMan 31 Posted December 18, 2015 Author Posted December 18, 2015 HV1 is now used for Continue Watching items, if enabled in the settings. In effect, although the names haven't changed, HV1 is now HV2 and HV2 is now HV3. Ah, that makes sense (kinda). Thanks!
cmcg 876 Posted December 18, 2015 Posted December 18, 2015 I hope that makes sense to people. The idea is to allow you to always have two different home age views with Continue Watching dynamically popping in to HV1 when you have some and shifting the other two down (obviously HV2 then drops off the bottom). I much prefer it. But it's optional as you'd expect.
FrostByte 5453 Posted December 18, 2015 Posted December 18, 2015 I think once you read the description in the app it makes sense, but for long time users who weren't aware the option was added it may come as a surprise since it's on by default 1
