JeremyG 30 Posted December 18, 2015 Posted December 18, 2015 (edited) Trying to find out what this happens. All my meida collections are "mixed content" except for Music. (because otherwise the UI is drastically different across devices) The 3 problems are: - Trailers image is compressed (this is the trailers channel, but shown on peer level with media folders) - The music image is stretched - The folders icon shows up, and I have no idea how to get rid of it. I think this only showed up after I enabled "Show Folders View" in the Windows Store client. (cause in that client you can NEVER get a folder view per-library unless you enable that option) Edited December 18, 2015 by JeremyG
Luke 42240 Posted December 18, 2015 Posted December 18, 2015 all of the apps have designed their UI's around the top level folder tiles having 16*9 images, so anything else you supply might have side effects. it's stretching music because the web client thinks it's close enough to 16*9, whereas trailers is really far off so it doesn't stretch it. best thing to do is make them 16*9, even if it's a png with transparency to keep your box shapes.
JeremyG 30 Posted December 18, 2015 Author Posted December 18, 2015 I'm just confused because all of the images in use there are exactly the same size. 454x455
