Grumpy1 46 Posted December 17, 2015 Posted December 17, 2015 Been a long time Plex user and love where Emby is going so i want to try both plex and Emby Since i have a 2012 Samsung ES8000 i need to install Plex the same way Emby is installed(user apps), But every time i install Emby it deletes Plex and vice versa . Are you only allowed to have 1 user app installed on Samsung at a time or is there a way around this. Didn't know if this is the best place to ask but couldn't find anything searching Google. thanks
FrostByte 5453 Posted December 17, 2015 Posted December 17, 2015 That's not how it works on my F8000. I have to re-add my Emby shortcut to MyApps whenever I install a newer version, but it doesn't delete other apps. I know @SamES has the same model as you and is very smart, maybe he can help.
FrostByte 5453 Posted December 17, 2015 Posted December 17, 2015 (edited) Makes sense. I believe Plex is on the Samsung store now so maybe reloading Plex from there would eliminate the issue, you just wouldn't have the latest and greatest developer version of Plex though Edited December 17, 2015 by FrostByte
Grumpy1 46 Posted December 17, 2015 Author Posted December 17, 2015 (edited) The problem is not having more than von app, the problem with developer apps is that you only can have one devolper account which is synced to one specific IP. If you change the IP it completely syncs all apps from the new developer server and deletes apps from another developer IP. Ok that makes sense, didn't know that it worked that way. Makes sense. I believe Plex is on the Samsung store now so maybe reloading Plex from there would eliminate the issue, you just wouldn't have the latest and greatest developer version of Plex though Yeah that does work but like you said the newer versions run a lot better edit-Just downloaded the zip for Emby and ran both plex and emby through Sammy Widgets and all is good now thanks guys Edited December 17, 2015 by Grumpy1 1
SamES 1084 Posted December 17, 2015 Posted December 17, 2015 (edited) If you have a NAS or something running a webserver at home, you can manually download the packages for both services and host them yourself. I haven't tried hosting two packages from the same host but I expect it should work fine. This is actually how I host the current Emby client for myself, this allows me to quickly swap test versions. If you need some tips on getting it running, let me know. Edited December 17, 2015 by SamES
Grumpy1 46 Posted December 17, 2015 Author Posted December 17, 2015 If you have a NAS or something running a webserver at home, you can manually download the packages for both services and host them yourself. I haven't tried hosting two packages from the same host but I expect it should work fine. This is actually how I host the current Emby client for myself, this allows me to quickly swap test versions. If you need some tips on getting it running, let me know. Thanks I actually got them both working through Sammy Widgets. 2
