Toonguy 5 Posted December 9, 2013 Posted December 9, 2013 It's me again. I have installed the SNESBOX and NESBOX plugins, but I am not sure what I need to do to make sure they show up in the media directory so that I can actually use them in gamebrowser. Do I just link directly to the URL or is there something else I should be doing?
Toonguy 5 Posted December 9, 2013 Author Posted December 9, 2013 Maybe that's the problem. I didn't have any libraries set up. That'll keep me busy for a while.
Solution Luke 42253 Posted December 10, 2013 Solution Posted December 10, 2013 assuming you already have GB setup with your NES and SNES libraries, the plugin will add NesBox links to the web client. 1
Toro 0 Posted January 3, 2014 Posted January 3, 2014 I must be a dunce also, I'm still not sure what this plugin (and snes) do ? My understanding is that it adds these flash game links to a folder in my game section. Other than downloading this plugin, does it require an emulator ? (I thought not since they were flash games) All i seem to get is an empty NES folder with nothing in it.
Luke 42253 Posted January 3, 2014 Posted January 3, 2014 it adds links in the web client to open flash versions of the game. you have to already have the nintendo roms in your game library, with the gamebrowser plugin
