Ability to select DLNA output interface
Currently DLNA only picks one interface to transmit out over, and in my case it consistently picks the outwards facing ethernet port (public IP) instead of the internal network. So in my case, DLNA doesn't work, at all.
Being able to select which interface to bind it to would be amazing..
Or, you know, bind it to all interfaces :D
  • Like 1
