Luke 42289 Posted June 12, 2016 Posted June 12, 2016 why don't you just manually mark your existing files as hidden if that's what you really want?
stephane.dunog 0 Posted June 12, 2016 Posted June 12, 2016 won't it disturb emby retrieving files ? for example, if fanart is : 'fanart.jpg' , after manually hiding this file it will be '.fanart.jpg' : the "dot" won't be a problem ?
stephane.dunog 0 Posted June 12, 2016 Posted June 12, 2016 if i hide a file, then its name start with a dot, isn't it ?
stephane.dunog 0 Posted June 12, 2016 Posted June 12, 2016 I finally have manually hidden all metadata and everything seems to work fine. Thanks a lot
stephane.dunog 0 Posted June 26, 2016 Posted June 26, 2016 In fact, it's not working. As i add new content, metadata stay visible although i have chosen to hide them. I don't want to hide manually each time i add a new movie. Have you any idea ?
Happy2Play 9814 Posted June 26, 2016 Posted June 26, 2016 @@Luke will have to comment if this is a OS issue since it works in Windows.
Luke 42289 Posted June 26, 2016 Posted June 26, 2016 I'm not sure to be honest, i'll have to test it. It's possible that for mac a different procedure is needed to make a file hidden.
