crunchyemby 9 Posted December 14, 2015 Posted December 14, 2015 Environment Details: client version: 2.5.47 and 2.5.48 (verified issue on both versions) server version: 3.0.5781.5 device: Droid Turbo (OS Version: 5.1) Description of Problem: When navigating through "Movies" content the view stack loses position... and returns the user to the "Suggestions" tab. Steps to reproduce: kill app open app select any movie content category select the "MOVIES" tab select any movie in the library (opens details page) From the 'Details >> Links" section, select "Website" wait for the built-in browser to load the web page select back (as expected, the UI is now on the movie detail page, from step 5) select back again EXPECTED RESULT: UI should go to "MOVIES" tab ACTUAL RESULT: UI is now on the SUGGESTIONS tab WORKAROUND: killing and re-opening the app, is the only way to recover the expected navigation behavior. Once reset, the navigation works as expected, until opening a link (i.e., step 6)
Luke 42242 Posted December 14, 2015 Posted December 14, 2015 Thanks. Interesting that it functions normally prior to clicking links. I'll test that out.
