Schimi 26 Posted December 14, 2015 Posted December 14, 2015 HI, i had done a clean install on my VM and noticed that there is no option to turn frame analysis on... in the xml i found the "<EnableVideoFrameByFrameAnalysis>false</EnableVideoFrameByFrameAnalysis>"
DrWatson 62 Posted December 14, 2015 Posted December 14, 2015 Ah thanks you helped me find it http://emby.media/community/index.php?/topic/28556-transcoding-to-hls-issue/
Luke 42185 Posted December 14, 2015 Posted December 14, 2015 people had been enabling it, not reading the description, and then reporting problems with slow scans. We can only really take so much of that before we stop and look for alternative techniques, which we are here for example http://emby.media/community/index.php?/topic/28474-305824-chrome-transcoding/
Schimi 26 Posted December 14, 2015 Author Posted December 14, 2015 So, what you mean? Is better for me to enable it or let it disable.... My server streams to firetv (stick and box) and chromecast.... Sync is used on winrt app and (if available ) ios thx for your opinion
ebr 16307 Posted December 14, 2015 Posted December 14, 2015 Your regular FireTV should be able to direct stream most items (unless they are something like folder rips) but not the stick.
Schimi 26 Posted December 14, 2015 Author Posted December 14, 2015 Your regular FireTV should be able to direct stream most items (unless they are something like folder rips) but not the stick. it's transcoded because of bandwidth But that's is "ok".... that's why i ask about frame analysis.... to "help" the transcoding process....
