dsig 2 Posted December 13, 2015 Posted December 13, 2015 I just loaded my P drive last night .. I wanted to look at the 'tag' editor and figured Metadata Manager was the way to go. That was 5 minutes ago and still running. Is it trying to read in all the metadata from all the files or ?? Is there an "optomize" db I need to run? What is the preferred method of editing metadata (tags).
Solution Luke 42185 Posted December 13, 2015 Solution Posted December 13, 2015 the metadata manager is on our to do list to rework. for now it is easier to use the regular browsing section to find the title you want to edit, then launch the editor from there 1
